[OpenFOAM] Drag Force from Forces Function different from Paraview |
November 26, 2018, 10:12 |
Ed O'Malley
Rep Power: 8 |
Hi -
I've noticed an interesting issue - when I use OpenFoam to do runtime drag force calculations, they are different than when I calculate them in Paraview. At the same time step, OpenFoam calculates the force to be 2.28N and Paraview gets 1.83N. In Paraview, after loading the case I do Extract Block on the geometry, then Extract Surface, then Generate Surface Normals, including cell normals. Then Calculator using cell normals, p*Normals_X, then Integrate Variables and display the Cell Normals attribute. In OpenFoam, here is my forcesIncompressible file. This is a Spalart-Allmaras DDES simulation using pisoFoam. Any idea what is going on and which one (if any) is accurate? Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | ------------------------------------------------------------------------------- Description Calculates pressure and viscous forces over specified patches for a case where the solver is incompressible (pressure is kinematic, e.g. m^2/s^2). \*---------------------------------------------------------------------------*/ #includeEtc "caseDicts/postProcessing/forces/forcesIncompressible.cfg" rhoInf 1.225; // Fluid density patches (Shoe1); outputControl timeStep; outputInterval 250; CofR (0.03 0 0.03); pitchAxis (0 1 0); // ************************************************************************* // |
November 30, 2018, 04:00 |
anonymous
Rep Power: 14 |
Hi!
OF calculates the viscous forces too. But I think in paraview you miss this component. |
December 10, 2018, 12:21 |
Ed O'Malley
Rep Power: 8 |
December 13, 2018, 09:15 |
Yann
Rep Power: 26 |
pisoFoam, as many other incompressible solvers is based on the kinematic pressure, which is basically the pressure normalized by density: You can make sure of that by checking the pressure dimensions in the p file. It should be either m2/s2 if the solver use kinematic pressure or kg/(m.s2) for regular pressure. E.g in pisoFoam: Code:
FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; Using the example you gave in your initial post, it would be something like 1.83*1.225=2.24N, which is closer to what openFoam computes. I don't know what can cause the remaining difference. Write precision ? Interpolation somewhere in the process ? For such thing I usually just load the patch(es) I want to work with in paraView so I don't use extract block and extract surface filters. |
December 13, 2018, 23:44 |
Ed O'Malley
Rep Power: 8 |
Great, thanks!
drag, forces |
Display Modes | |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
FLUENT: how to record drag force at every time step? | qiulan | FLUENT | 4 | March 20, 2017 21:22 |
Wrong forces coming from forces function object in controlDict | Jason_Duguay | OpenFOAM Post-Processing | 0 | April 13, 2016 09:07 |
Force vectors for drag during sweeping motion | aamer | FLUENT | 0 | April 18, 2011 08:17 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
