sajad alimardani
Rep Power: 5 ![]() |
hi
I simulate transient flow around of the propeller(pimpleDymFoam) and compare with steady data. my result Component velocity on the slice blade so different with Experimental results( Experimental results is steady state). i use average-field for this. clip/clip/slice/plotintersictioncurve/ U_xmean ,U_ymean... so different ![]() Somebody has an idea. ![]() thank you. sajjad /* fieldAverage1 { type fieldAverage; functionObjectLibs ( "libfieldFunctionObjects.so" ); enabled false; outputControl outputTime; fields ( U { mean on; prime2Mean on; base time; } p { mean on; prime2Mean on; base time; Last edited by sajjjad; January 15, 2019 at 08:48. |
sajad alimardani
hi my friends
I think the fieldAverage code is based on the location and not the cell's index. That is, the mean values do not fluctuate with the propeller and are specific to the same place how can use average field on dynamic mesh?????????? thank you sajjad Last edited by sajjjad; January 16, 2019 at 02:54. |
Nejc
Rep Power: 6 ![]() |
You can specify surfaceFieldValue on a patch:
type surfaceFieldValue; operation average; fields (p); writeFields no; regionType patch; name blade; |
#4 | |
sajad alimardani
thank Nejc for ripely.I'm sorry. i explain my problem Incomplete. i want average not on the blade.in fact on the slice radial(such this picture) sajjad thank you. |
#5 | ||
Retired Super Moderator
Bruno Santos
Rep Power: 123 ![]() ![]() ![]() ![]() ![]() ![]() |
Since I couldn't find a thread on this, I'm post here the answer to the following PM from sajjjad:
Display Modes | |
how to calculate water average velocity in free surface models | hmasenger | CFX | 22 | October 30, 2019 19:28 |
Average velocity of two different planes | niqbal | OpenFOAM Post-Processing | 6 | June 19, 2017 06:08 |
Finding Average velocity between two plates | EP3engineer | CFX | 2 | January 31, 2015 12:47 |
Troubleshooting probe and average functions with Angular Velocity | siardica | CFX | 20 | October 7, 2013 06:54 |
how to get average velocity in a given domain | W. W. Zhang | FLUENT | 1 | May 6, 2007 12:25 |
