January 16, 2019, 09:42 |
Plotting Q-criterion
Nejc
Rep Power: 9 |
Hi.
I'd like to visualize spots with dissipation losses in my domain (a transient k-omega SST pimpleFoam case with dynamic mesh). I have the following options:
I have found many examples of Q-criterion but my problem is that the values range from say -1e+17 to +1e+17. How do I choose values for isosurface plots so that they give me the most information? Thanks! |
January 16, 2019, 09:51 |
Anton Kidess
Rep Power: 29 |
AFAIK there is no real way to chose the value for the isosurface - you choose what looks good (see [1]). However, your value range seems unbounded, which makes me believe you may have a small error in your computation.
[1] Dubief, Y., Delcayre, F., 2000. On coherent-vortex identification in turbulence. Journal of Turbulence 1. URL http://dx.doi.org/10.1088/1468-5248/1/1/011
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
January 16, 2019, 15:58 |
Nejc
Rep Power: 9 |
Thanks for the reply.
Actually the values are more like -1e+7 to 1e+7; does that make any difference? What range should Q-criterion usually be in? |
February 18, 2019, 11:07 |
Lucky
Rep Power: 65 |
The range of Q-criterion is normally some finite negative number to positive infinity. That you have a nice symmetric negative 1e7 and positive 1e7 suggests you might have some bug. But it might still be correct. Anyway, just check.
The isosurface of Q-criterion you should plot is "some positive number that you like" Q-criterion is also dimensional in its pure definition, so one type of flow you take Q=1 and another type of flow you might take Q = 1000. You could normalize the Q-criterion to help with this. But because this is so hard to decide (it's quite arbitary what this threshold is), the closely related lambda 2 criterion is often preferred over Q-criterion (where the threshold is 0). |
February 18, 2019, 16:14 |
Nejc
Rep Power: 9 |
Lambda2, you say.
Never heard of that, will try out, thanks a lot! |
February 19, 2019, 04:20 |
Anton Kidess
Rep Power: 29 |
The paper I linked in my post a month ago also explains the lambda2 criterion.
February 19, 2019, 07:54 |
Nejc
Rep Power: 9 |
...but unfortunately isn't available without paid access.
September 11, 2020, 11:01 |
#8 | |
MA
Rep Power: 6 |
Hi LuckyTran, I am struggling with the same. Although I have created Q-criterion but half of the blade is taken away (maybe due to the flow separation) however I have to compare my RANSE Q-Criterion (STARCCM) with reference Q-Criterion (LES)as you can see in the attached images. Why the half of blade is taken away, is there anyway to fix this issue and represent the whole Q-criterion on the blade surface? |
[General] 3D plot Q criterion | Ursmooth | ParaView | 1 | November 25, 2021 14:42 |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 09:48 |
[ANSYS Meshing] 'Element quality' meshing criterion | RobBanks | ANSYS Meshing & Geometry | 2 | May 2, 2018 12:21 |
Stopping criterion for outer iteration loop | luftraudi | Main CFD Forum | 3 | February 22, 2017 08:59 |
Asymptotic stopping criterion is not working | rob50904 | STAR-CCM+ | 2 | January 28, 2013 08:25 |
