-   OpenFOAM Post-Processing (https://www.cfd-online.com/Forums/openfoam-post-processing/)
-   -   probes - command not found (https://www.cfd-online.com/Forums/openfoam-post-processing/214131-probes-command-not-found.html)
Rasmusiwersen January 21, 2019 05:54
Hello all,
I am using OF 2.2.2, and trying to post process the velocity field after running oscillatingPimpleFoam.
My goal is to extract the velocity at a certain point, using probes. In the OF userguide version 6 page U-193 and U-194 the following is suggested:
foamGet probes from the /system directory, however when typing "foamGet probes" in the system folder, i get the error "Command not found".
Is this due to the version of OF I am using? Is there any other way to obtain velocities at certain points in my domain?
Thank you for your time!
/Rasmus
