[OpenFOAM] cutting plane doesn't view results completely |
April 11, 2019, 02:28 |
Justin Maris L. Natividad
Rep Power: 10 |
Good day. I encountered a problem regarding viewing my results in Paraview. I've set up a run of dispersion of aerosol in an urban canyon setting. Then I used the cutting plane tool to view my results ( I can't view it directly because I am running it in an HPC). Then as I view my results, it seems that at the start of the dispersion of aerosols (I started it at 1500, my timesteps was up to 3000, with 0.5 as my interval) the results are not complete, but as the time steps grew, it returns to normal. How can I fix this? I've attached pictures for reference. Thank you very much for the consideration on this matter
April 26, 2019, 16:28 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: I don't know if you've figured out what was the problem, but without more details about how you configured things, which ParaView version you used and how exactly you were accessing the data, it's not even possible to reproduce this issue.
My best guess is that the "cutting plane tool" you've used was configured to cut with a clipping sphere that somehow worked in function of time...
View with cut plane | Mudblood | FLUENT | 5 | April 4, 2020 10:17 |
Measure the surface of the faces of a triangulated cutting plane | Pagoda | OpenFOAM Post-Processing | 3 | August 20, 2018 09:51 |
View Layer Results when Keyopt 8 is ON | RJKhan | ANSYS | 0 | May 27, 2017 23:51 |
Stepping through cutting plane results using ParaFoam | alanaj5 | OpenFOAM Post-Processing | 1 | September 13, 2016 03:34 |
how to view the complete results | shokry | FLOW-3D | 5 | February 3, 2009 13:56 |
