Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
reconstruction error
Old   April 12, 2019, 08:23
Default reconstruction error
Hampshire
oneya is on a distinguished road
When I was executing the command 'reconstructPar', I obtain the following error,
PHP Code:
Reconstructing fields for mesh region0
Time
1.28000000
Reconstructing FV fields
    Reconstructing volScalarFields
        k_0
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigSegv::sigHandler(int) at ??:?
#2   in "/lib64/libc.so.6"
#3  Foam::symmetryPlaneFvPatchField<double>::symmetryPlaneFvPatchField(Foam::symmetryPlaneFvPatchField<double> const&, Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::fvPatchFieldMapper const&) at ??:?
#4  Foam::fvPatchField<double>::addpatchMapperConstructorToTable<Foam::symmetryPlaneFvPatchField<double> >::New(Foam::fvPatchField<double> const&, Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::fvPatchFieldMapper const&) at ??:?
at ??:?
at ??:?
at ??:?
at ??:?
at ??:?
#10  __libc_start_main in "/lib64/libc.so.6"
#11
at ??:?
Segmentation fault (core dumped
If anyone has ideas about what causes this and how to fix? Thanks.
oneya is offline   Reply With Quote
Old   November 16, 2019, 08:39
汤龙民
tanglm is on a distinguished road
Hello Hampshire,
Have you solved your problem? I came across the same error massage as yours.
tanglm is offline   Reply With Quote
Old   September 20, 2022, 06:49
AlxB is on a distinguished road
I am using OF-v2112 and the problem still exists.
With InterFOAM, reconstructPar fails as below:
HTML Code:
        Co
#2  ? in /lib/x86_64-linux-gnu/libpthread.so.0
#3  Foam::IOobject::path() const at ??:?
AlxB is offline   Reply With Quote
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
