Expected a ')' while reading binaryBlock, found on line 20 an error
Hi Former
I have data from a simulation which was done with HPC ( High Performance Computer, basically a super computer). I would like to post-process them by using Para View in a virtual machine. When I run para View, the terminal give me this error. Code:
I/O : uncollated |
Problem solved
I fixed the problem.
Basically, there is a setting in Para View which is called "-builtin". By using it to launch Para View, I have the oportunity to select my Label_Size (between 32 and 64 bit) before apply the results. In the terminal, it should be typed HTML Code:
parafoam -builtin Daniele |
