-   OpenFOAM Post-Processing (https://www.cfd-online.com/Forums/openfoam-post-processing/)
-   -   fft in openFOAM (https://www.cfd-online.com/Forums/openfoam-post-processing/217491-fft-openfoam.html)
manafaero May 14, 2019 09:48
fft in openFOAM
hi
I want to do a FFT of the spatial data, i.e. FFT for the data extracted over a line, This FFT is then computed for each time step in OpenFOAM. Can anybody help me with the same.
Thanking you
Swift May 23, 2019 11:11
Hi Manaf,
Does an FFT of spatial data make sense? What frequency would you expect to get? The mesh size? What are you trying to achieve?
I would think that you need to record the data at a point verses time and take an FFT of that.
If you really want to do as you describe, you should be able to create a line source in paraview and export that for all times to a spreadsheet or csv file. You would then need to use python or similar to reconstruct the data into a format that you could take an FFT.
I don't think there a native way to do FFT in Openfoam.
Good luck.
Thomas
manafaero May 24, 2019 06:11
Thank you sir
gigilentini8 September 10, 2020 14:56
Thomas you are wrong!
there a nice little FFT library in OpenFOAM for cartesian meshes
https://cpp.openfoam.org/dev/dir_afc...e9c4c8c41.html
Originally Posted by Swift (Post 734608)
Hi Manaf,
Good luck.
Thomas
HPE September 10, 2020 18:13
I increase the bid:
FFTW is a part of OpenFOAM. You can use FFTW inside OpenFOAM, therefore.
PS: at least the com version.
