Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
functionObject type = faceSource
Old   February 11, 2016, 11:58
Default functionObject type = faceSource
Gabriele
leske is on a distinguished road
Hello, I' m trying tu run my case with this functionObject that i copied here: /opt/openfoam240/src/postProcessing/functionObjects/field/fieldAverage
When i run interFoam, i get this output error:
--> FOAM FATAL IO ERROR:
keyword sourceName is undefined in dictionary "/home/gabriele/OpenFOAM/gabriele-2.4.0/run/prova/system/controlDict.functions.faceObj1"
file: /home/gabriele/OpenFOAM/gabriele-2.4.0/run/prova/system/controlDict.functions.faceObj1 from line 55 to line 87.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 442.
Below the script that i put in controlDict:
functions
faceObj1
type faceSource;
functionObjectLibs ("libfieldFunctionObjects.so");
enabled true;
outputControl outputTime;
// Output to log&file (true) or to file only
log true;
// Output field values as well
valueOutput true;
// Type of source: patch/faceZone/sampledSurface
source sampledSurface;
// if sampledSurface: dictionary with a sampledSurface
// Note: will not sample surface fields.
sampledSurfaceDict
// Sampling on constantPlane
sourceName piano1;
type plane; // always triangulated
basePoint (0.41 0 0);
normalVector (-1 0 0);
// Operation: areaAverage/sum/weightedAverage ...
operation areaAverage;
fields
p
Someone has an idea from where is the problem?
Thank you
leske is offline   Reply With Quote
Old   February 11, 2016, 12:02
Gabriele
Sorry, in the script there isn't the line:
sourceName piano1;
anyway openFoam still gives me the same error both with and without this line
Old   November 8, 2018, 07:54
Default OpenFoam
Manaf Muhammed
manafaero is on a distinguished road
Dear friend can you find out the problem. I am also facing the same.please help.
manafaero@gmail.com
manafaero is offline   Reply With Quote
Old   May 30, 2019, 06:54
Deep
deepbandivadekar is on a distinguished road
Old thread (and this could be a version issue.)
But for anyone seeking answers to get patch data in OF6 I just added a comment here: The syntax has changed a bit, that's all.
deepbandivadekar is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
Simulation of Radial Fan with simpleFoam MRF nash OpenFOAM Running, Solving & CFD 2 November 5, 2015 10:12
interFoam/kOmegaSST tank filling with printStackError/Mules simpomann OpenFOAM Running, Solving & CFD 3 February 17, 2014 17:06
[swak4Foam] Air Conditioned room groovyBC Sebaj OpenFOAM Community Contributions 7 October 31, 2012 14:16
pipe flow with heat transfer Fabian OpenFOAM 2 December 12, 2009 04:53
