Flow rate and phi not matching??
Hi guys,
I've got an interesting situation. I've got 2 inlet patches, each set to: Inlet1 { type flowRateInletVelocity; volumetricFlowRate constant 65; } Now after monitoring the velocity magnitude at a few slices in the domain im happy the simulation has converged. In the U file at one of these advanced time steps, think its time step 4840. I have this: Inlet1 { type flowRateInletVelocity; volumetricFlowRate constant 65; extrapolateProfile false; value uniform (0 6.02545 0); } All look ok right?? Well if I try this command: postProcess -func 'patchAverage(name=Inlet1,U,p)' -latestTime surfaceFieldValue patchAverage(name=Inlet1,U,p): total faces = 865 total area = 10.7876 Time = 4840 Reading fields: volScalarFields: p volVectorFields: U Executing functionObjects surfaceFieldValue patchAverage(name=Inlet1,U,p) write: average(Inlet1) of U = (0 6.02545 0) average(Inlet1) of p = 101325 End Again this is what I expect. This is where it gets weird: If I run postProcess -func "flowRatePatch(name=Inlet1)" -latestTime I get....... surfaceFieldValue flowRatePatch(name=Inlet1): total faces = 865 total area = 10.7876 Time = 4840 Reading fields: surfaceScalarFields: phi Executing functionObjects surfaceFieldValue flowRatePatch(name=Inlet1) write: sum(Inlet1) of phi = -30.743 End So how can it be a surface of approx 10m2 with an average velocity of approx 6m/s giving my requested flow rate of 65m3/s (approx) but have a flux across it equal to 30.743m3/s??? Any thoughts???? |
Hello Brett,
What solver are you using? First thing coming to my mind would be volume flowrate VS mass flowrate. |
Hi Yann,
Just simpleFoam, so I've not defined the density. Any other thoughts? |
without knowing your case. I think you are doing anything wrong - somewhere. I just redone all your steps in the pitzDaily case and everything works fine. No problems at all an all results are as expected. By the way, please use code-tags. |
@Bdew8556 I'm having the exact same issue but the ratio of volumeFlowRate and phi is coming out as 30 in my case.
Have you managed to solve this issue? |
