June 12, 2019, 01:36 |
surfaceFieldValue from faceZone issue
Gino Parisella
Rep Power: 9 |
Hi there,
I've got this funny issue: Code:
--> FOAM Warning : surfaceFieldValue my_patch: faceZone(samplingPatch): Region has no faces From function void Foam::functionObjects::fieldValues::surfaceFieldValue::initialise(const Foam::dictionary&) in file fieldValues/surfaceFieldValue/surfaceFieldValue.C at line 545. From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 817 --> while loading function object 'my_patch' Code:
{ type surfaceFieldValue; libs ("libfieldFunctionObjects.so"); writeControl writeTime; writeInterval 1; fields (alpha.water U "p.*"); writeFields yes; regionType faceZone; name samplingPatch; operation none; } Code:
Checking faceZone topology for multiply connected surfaces... FaceZone Faces Points Surface topology samplingPatch 567 616 ok (non-closed singly connected) I am running the interFoam solver from OpenFOAM+ v1812 on Ubuntu 14.04. Any help would be much appreciated! Thanks in advance, Gino |
June 12, 2019, 04:06 |
Gino Parisella
Rep Power: 9 |
maybe the issue is with the faces being part of an "empty" type boundary? since the method does work on a similar 3D domain case. Someone more experienced than me can confirm this.
although the boundary type is empty, those faces are part of cells that still have scalar and field variables, so I would expect the faces' values to be the same as the cells? Perhaps I totally have the wrong ideas anyway the above method does not (or should not) work for faces belonging to an "empty" type boundary Cheers EDIT; volFieldValue with a cellZone could be used for 2D cases (see user guide) Last edited by ginop; June 12, 2019 at 05:37. Reason: adding details |
December 1, 2020, 09:35 |
Parallelization?
Tobias Kienzler
Rep Power: 6 |
I encountered the same error, and it turns out to be due to parallelization which leaves the interesting patch empty on some nodes empty. I don't know if there is any way to modify the functionObject to skip / consider those empty patches to non-contributing, so for now I had to comment out that part in my controlDict and post-process the reconstructPar-ed case...
[swak4Foam] swakExpression on faceZone returns empty field for non-empty zone | jgross | OpenFOAM Post-Processing | 1 | July 7, 2022 11:28 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
Calculate Mass Flowrate at a faceZone with OpenFOAM4 | donQi | OpenFOAM Post-Processing | 1 | August 31, 2016 21:13 |
Problem with Application based on a faceZone in parallel | psilkeit | OpenFOAM Programming & Development | 2 | April 28, 2016 09:47 |
