Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
How to display thermal gradients in Paraview
Old   June 20, 2019, 04:00
Default How to display thermal gradients in Paraview
Adam
Adam_K is on a distinguished road
I am using the chtMultiRegionFoam solver to look at transient conduction through multi-phase systems. The simulations are running correctly and I am able to visualize the temperature maps using Paraview, however I would like to be able to see the thermal gradients as well.
When I apply the Gradient of Unstrcutred DataSet filter in Paraview I get the following error:
ERROR: In C:\bbd\ecd3383f\build\superbuild\paraview\src\VTK\Filters\General\vtkGradientFilter.cxx, line 318
vtkGradientFilter (00000205FBC4A420): No input array. If this dataset is part of a composite dataset check to make sure that all non-empty blocks have this array.
ERROR: In C:\bbd\ecd3383f\build\superbuild\paraview\src\VTK\Common\ExecutionModel\vtkExecutive.cxx, line 782
vtkPVCompositeDataPipeline (00000205F4C65220): Algorithm vtkGradientFilter(00000205FBC4A420) returned failure for request: vtkInformation (0000020592472820)
  Debug: Off
  Modified Time: 19414550
  Reference Count: 1
  Registered Events: (none)
  Request: REQUEST_DATA
  FROM_OUTPUT_PORT: 0
  FORWARD_DIRECTION: 0
  ALGORITHM_AFTER_FORWARD: 1
In the T file, I can see the following lines, so it looks like a gradient has been calculated (although I don't see a direction associated to these magnitudes).:
        refGradient     uniform 0;
        valueFraction   nonuniform List<scalar>
1520
0.0033887263
0.0033894414
Can anyone point me in the right direction? I have seen some cases where people need to modify the solvers itself in order to export certain fields but for something as simple as dT/dx, dT/dy and their magnitude it seems like there should be an easier way.
Adam_K is offline   Reply With Quote
Old   June 21, 2019, 03:27
Zander Meiring
yambanshee is on a distinguished road
Have you tried the "Gradient Of Unstructured Data Set" filter in paraview?
yambanshee is offline   Reply With Quote
Old   June 21, 2019, 03:31
Adam
Yes, it was my first approach. The error message that paraview gave me is in the original post.
Old   June 24, 2019, 03:08
Zander Meiring
Sorry, I think I was a bit too scatter brained when I replied!
It seems as though the parafoam doesn't have the temperature values everywhere that you are requesting. Maybe make sure that only the internal mesh is selected, and if you're doing a 2d simulation, take a slice of the domain?
Old   June 25, 2019, 04:39
Adam
Ah thanks! That was it. All three of the following were checked by default. Removing the first one allowed it to correctly display the gradients.
internalMesh
phase1/internalMesh
phase2/internalMesh
decomposePar -cellDist: Display cellDecomposition in ParaView Sean95 OpenFOAM Post-Processing 4 January 24, 2019 10:56
[OpenFOAM] Paraview display problem jiejie ParaView 4 October 13, 2013 21:29
[OpenFOAM] Display lift and Drag in paraview SamerAli ParaView 1 May 16, 2013 12:51
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 07:11
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
