August 8, 2019, 10:01 |
Extract body points coordinate snappyhexmesh
Andrew
Rep Power: 8 |
Hi guys, i have done a simple mesh of an airfoil, i would like to know how to extract the coordinates of points of the mesh that are on the airfoil patch
Thanks you for any answers Anstan |
August 14, 2019, 03:45 |
anonymous
Rep Power: 14 |
Hi!
You need it for external processing? This is a pretty brute force solution, but in the polyMesh/boundary file you can find the starting face of that patch and the number of faces. then in the polyMesh/faces file you can find the points for these faces. In the polyMesh/points file you find the coordinates for these points. But there is a much simpler way using paraView. Open the case, load only the needed patch, create a SpreadSheet view, and you will find the coordinates in the Points column. And you can export it as a csv file. This is simpler, but the first method is more challenging |
August 15, 2019, 03:02 |
Andrew
Rep Power: 8 |
Hi simrego thanks you very much for the help!
Astan |
[snappyHexMesh] snappyHexMesh, new timestep creation and field and mesh dont have the same #points | Loekatoni | OpenFOAM Meshing & Mesh Conversion | 1 | November 23, 2018 09:11 |
Deformations in a Coordinate System that rotates (moves) with the solid body | Pumpov | Structural Mechanics | 4 | September 10, 2018 08:00 |
sample utility of OF2.3.1 provides less points | aCFDuser | OpenFOAM Post-Processing | 7 | May 1, 2017 21:25 |
TimeVaryingMappedFixedValue best practice to extract subset points and fields | podallaire | OpenFOAM Running, Solving & CFD | 6 | May 21, 2014 10:25 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
