Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Area Weighted Average
Like Tree7Likes
  • 4 Post By santos
  • 2 Post By srv537
  • 1 Post By Gerhard
Old   July 19, 2010, 09:27
Default Area Weighted Average
Balkrishna Patankar
balkrishna is on a distinguished road
Please can someone document a method to find the area weighted average of a variable in OpenFOAM. The source code is really complex to figure out for someone who has a basic programmers insight. Would be of great help if anyone would do so . The Doxygen documentation is not very helpful either for beginners .All it gives are links to headers files without actual descripton of what a variable is . Also please comment a lot when writing any solver for OpenFOAM . A very good example is the way Linux source code is written. Loads of comments explaining every line in detail.
balkrishna is offline   Reply With Quote
Old   July 19, 2010, 09:55
Sandeep Menon
deepsterblue will become famous soon enough
It's not entirely clear what you intend by an 'area-weighted' average. Do you intend to perform a weighted average based on mesh face-patch values? OpenFOAM is a three-dimensional code, so volume-weighted averages for cell variables are usually the norm.
Either way, you can perform a weighted average (either patch face-areas or cell-volumes) using the DimensionedField member function:
//- Calculate and return weighted average
dimensioned<Type> weightedAverage
const DimensionedField<scalar, GeoMesh>&
) const;
Take a look at $FOAM_SRC/finiteVolume/cfdTools/general/include/volContinuity.H for a cue on how it's done.
Also, writing code is hard work, and documenting it can be often time-consuming, which is why it may not be done at all times. Of course, if you're willing to pay for it, I'm sure you'll find a bunch of people who would oblige.
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   July 20, 2010, 01:21
Balkrishna Patankar
Thanks . But how do i actually use it while solving a case . Like how do I call the function to actually find the volume weighted average .
Old   July 20, 2010, 05:10
Balkrishna Patankar
What i want to calculate is the pressure area weighted average on any face ....
sum(Af*p)/sum(A) on the boundary .... how do I go about it ?
Old   July 20, 2010, 05:15
Stefan Herbert
herbert is on a distinguished road
If you only want to calculate average values on patches for postprocessing, you can use simpleFunctionObjects.
Regards,
Stefan
herbert is offline   Reply With Quote
Old   July 20, 2010, 05:49
santos's Avatar
Jose Luis Santos
santos is on a distinguished road
Send a message via Skype™ to santos
Another option is to run:
patchAverage <field> <patch>
Regards,
Jose Santos
santos is offline   Reply With Quote
Old   February 28, 2011, 17:17
Wolfgang W.
WiWo is on a distinguished road
Hi!
Sorry if this comes like a stupid question ...
I was intending to use the patchAverage utility exactly as described above - works fine. BUT - where are the results actually written to? I don't see any additional files being created anywhere ...
Thanks for your help!
Cheers,
Wolfgang
WiWo is offline   Reply With Quote
Old   February 28, 2011, 17:21
santos's Avatar
Jose Luis Santos
Results are not written to any file unless you instruct it to, they are just output to the terminal.
If you want to write results to a file 'file' without any output in the terminal you can try:
patchAverage <field> <patch> > file &
Regards,
Jose
Old   March 1, 2011, 19:21
Wolfgang W.
Hi Jose,
Thanks a lot for your expeditious response! I was able to redirect the output of patchAverage to a file.
Unfortunately the style of the output with the accompanying text is not ideal for further processing. Thus I decided to change the code of patchAverage a little :-)
Cheers,
Wolfgang
Old   March 2, 2011, 07:05
Balkrishna Patankar
instead of meddling with the code i pass the file through tr and awk filters .... and get the output in the format i want it to be ...
Old   February 16, 2017, 07:54
Saurav Kumar
srv537 is on a distinguished road
Regards,
Jose
Hi santos,
actually, I am using OpenFOAM4 and interested to find Area Weighted Average for each time step.
I modified pimplefoam and it calculates gradT and average of gradT over patch surface.
gradT.boundaryFieldRef()[patchi]=T.boundaryFieldRef()[patchi].snGrad();
scalar area1 = gSum(mesh.magSf().boundaryField()[patchi]);
scalar sumField1 = 0;
if (area1 > 0)
sumField1 = gSum
* gradT.boundaryField()[patchi]
)/ area1;
Info<< " Average of gradT over patch 1 = " << sumField1 << endl;
and then i use to calculate Nu=(L/deltaT)*gradT.
in openfoam4 i have used
"mypimpleFoam -postProcess -func 'patchAverage(name=HEATEDWALL,gradT)' >log"
but it gives me Zero value and only at those time that i have saved for postProcessing.
Region type : patch HEATEDWALL
# Faces : 351
# Area : 3.50000000e-03
# Time average(gradT)
0 0.00000000e+00
1 0.00000000e+00
2 0.00000000e+00
3 0.00000000e+00
4 0.00000000e+00
5 0.00000000e+00
6 0.00000000e+00
7 0.00000000e+00
8 0.00000000e+00
9 0.00000000e+00
10 0.00000000e+00
10 0.00000000e+00
I want to save average(gradT) and average(wallShearStress) that i have calculated by " mypimpleFoam -postProcess -func wallShearStress" at all time step how can i do this, please suggest me.
Kind Regards,
srv
Luttappy and elmo555 like this.
srv537 is offline   Reply With Quote
Old   March 14, 2018, 09:41
Gerhard
Gerhard is on a distinguished road
Hi
This conversation really helped me. Thank you.
However, patchAverage does not calculate the area weighted average. It only calculates the average.
You can make it calculate the area weighted average by doing the following:
- Copy the patchAverage file from $FOAM_ETC/caseDicts/postProcessing to your case's system file.
- Change operation to areaAverage instead of average.
- include #includeFunc patchAverage under functions in controlDict.
- run the case and once done run: solver -postProcess (eg. simpleFoam -postProcess)
Good luck!
eirinikardabiki likes this.
Last edited by Gerhard; March 14, 2018 at 09:46. Reason: Pressed the send button by accident...
Gerhard is offline   Reply With Quote
Old   October 11, 2021, 22:37
Venkat Ganesh
Venky_94 is on a distinguished road
Can someone please suggest how to carry this out? I'm trying to do something similar, but within the solver code and not in postprocessing.
I need to obtain an area averaged value for the volume fraction in interfoam.
Venky_94 is offline   Reply With Quote
area, average, foam, open, weighted
Area weighted or mass weighted average SAM Main CFD Forum 31 April 30, 2018 04:12
Diffference between mass weighted average and Area giogio FLUENT 9 March 6, 2018 08:24
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
Area weighted average ashish FLUENT 1 April 12, 2005 18:02
area weighted average Sireesha Pasari FLUENT 1 April 4, 2004 13:06
