Problem of crossed cells while visualizing 3D mesh in 2D using ParaFoam
Like Tree2Likes
  • 2 Post By Flowkersma
Old   September 22, 2019, 02:56
Default Problem of crossed cells while visualizing 3D mesh in 2D using ParaFoam
chandra shekhar pant
chandra shekhar pant is on a distinguished road
Hello All,
I am trying to visualize the 3 D mesh around an object (for ex aerofoil). I took the object (aerofoil), slice it, then put the internalfield on, and then hide the block. But instead of getting clear cells the cells appeared to be crossed. By looking at the post I even tried the filter "ExtractCellsByRegion", but this also haven't helped. The mesh of crossed grid is attached herewith.
Thanks a lot!
chandra shekhar pant is offline   Reply With Quote
Old   September 22, 2019, 08:11
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
(Very likely) Nothing problematic related to the mesh itself. This is just visualisation itself provided by Paraview.
checkMesh utility is your friend to tangibly quantify your mesh quality.
HPE is offline   Reply With Quote
Old   September 22, 2019, 08:34
May thanks HPE for the prompt reply. But I was just exploring the better way of visualizing the mesh, so that it looks good. Thanks again for the help !
Old   October 9, 2019, 10:55
clapointe is on a distinguished road
Paraview will visualize using tets by default. The easiest way to visualize the cells (assuming that you are using predominately hexes) is to : load paraview with the "useVTKpolyhedron" box checked. Then you can take a slice through your domain (make sure it's through cells, not on cell faces), and uncheck the "triangulate slice" option for the slice. Then look at the slice as a surface with edges or a wireframe.
Caelan
clapointe is offline   Reply With Quote
Old   October 10, 2019, 02:15
Many thanks Caelan for your help. I am using paraview 5.01, and could not find the "useVTKpolyhedron" although tried to see some of the tutorials also but could not find it. I am very new to the parafoam so sorry for asking this naive query. It will be a great help if you could share the screenshot of the "useVTKpolyhedron".
Thanks again!
Old   October 10, 2019, 11:31
Check out this faq : http://openfoamwiki.net/index.php/FAQ/Postprocessing.
Caelan
Old   October 10, 2019, 13:32
Mikko
Flowkersma is on a distinguished road
ParaView automatically triangulates the slice. Deselect "Triangulate the slice" and select "Crincle slice" in the properties panel to visualize the mesh.
Best, Mikko
Flowkersma is offline   Reply With Quote
Old   October 11, 2019, 09:06
Hello Mikko,
Wow! it worked...Thanks a lot
Thanks a lot!
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 04:17
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
