substitutes of "boxToCell" and its application
when geometry is complex, what are the substitutes of "boxToCell"? regionToCell, zoneToCell, shapeToCell? could someone give 3 simple examples of how to use the above 3 as follows as with "setFields"? thank you in advance an application example of "boxToCell" in OF-tutorials: --------------------------------------------------------- boxToCell { box (0 0 0) (40.0 1.0 0.4046); fieldValues ( volScalarFieldValue alpha.water 1 ); --------------------------------------------------------- |
wrong place
btw. I also re-posted this thread in the pre-processing block.
sorry for wrong place thanks |
With searchableSurfaceToCell, you could specify an arbitrary enclosing surface "blob" (eg, an stl) and select based on that. In fact, since it is backed with a searchable surface, you could even specify using a searchable surface that is a box and it would be the same as boxToCell. You probably don't want to do that, but may be nice to know
https://www.openfoam.com/documentati...aceToCell.html Related: arbitrary surfaces for constraining domain decomposition: tutorials/preProcessing/decompositionConstraints/geometric/system/decomposeConstraints |
thank you, olesen
thank you, olesen for the reply.
I gonna have a look in detail to see if i still get question. in between thanks and regards |
