Sample From Decomposed Case Wo Reconstructing |
October 31, 2019, 04:55 |
Cagkan
Rep Power: 10 |
Hi everyone,
I have a case of a 2D wave flume simulation, that was run with interFoam as decomposed (8 processors) case. (OpenFOAM v1812) I needed 8 free surface elevation measurements from 8 different lines so I added them as Raw measurements of alpha.water to the functions sections in controlDict. Everything worked great I get my measurements at each time step simultaneously with the simulation but, I need to look a few centimetres before and after of these lines also. Now I need to re-take those samples but I don't want to reconstruct cases (also I don't have time to reconstruct them neither) is there any way to get samples from the existing, decomposed model without reconstructing or re-run the whole thing. Thank you for the answers in advance. |
November 1, 2019, 13:03 |
Abe
Rep Power: 9 |
Yep, post processing works with mpi and the -parallel flag. So do something like:
mpirun -np 8 interFoam -postProcess -parallel and it will just run your function objects on all the times. |
[General] Opacity and decomposed case | Fauster | ParaView | 0 | March 5, 2018 06:35 |
Post-process decomposed case after a simulation | scigowtham | OpenFOAM Post-Processing | 0 | May 7, 2017 03:07 |
Boundary Conditions - Decomposed Case | ThorgrimmCFD | OpenFOAM Post-Processing | 0 | January 7, 2015 10:44 |
Flux update during an MPI run between decomposed case parts? | scott | OpenFOAM | 0 | July 21, 2010 20:47 |
Sample not working in my case | sampaio | OpenFOAM Post-Processing | 1 | October 26, 2005 13:41 |
