Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
boundaryFoam postprocessing in the latest openFoam version
Old   October 30, 2019, 17:17
Default boundaryFoam postprocessing in the latest openFoam version
KTG
Abe
KTG is on a distinguished road
Hi everyone,
The update to the latest version of openFoam seems to have broken the postprocessing I was using for boundaryFoam. Its based on the surface mounted cube casefile, which no longer will run:
functions
    turbulenceFields
        type            turbulenceFields;
        libs            ("libfieldFunctionObjects.so");
        writeControl    writeTime;
        fields          (R nuTilda k epsilon omega L);
    surfaces
        type            surfaces;
        surfaceFormat   boundaryData;
        interpolationScheme cell;
        fields
            U
            turbulenceProperties:R
            turbulenceProperties:nuTilda
            turbulenceProperties:L
        surfaces
            inlet
                type            patch;
                patches         (inlet);
                interpolate     false;
This code gives me: --> FOAM FATAL ERROR: Unknown write type "boundaryData"
If I change the type to something valid, I get:
attempted assignment to self
    From function void Foam::DimensionedField<Type, GeoMesh>::operator=(const Foam::DimensionedField<Type, GeoMesh>&) [with Type = double; GeoMesh = Foam::volMesh]
    in file /home/ubuntu/OpenFOAM/OpenFOAM-7/src/OpenFOAM/lnInclude/DimensionedField.C at line 520.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::DimensionedField<double, Foam::volMesh>::operator=(Foam::DimensionedField<double, Foam::volMesh> const&) in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/boundaryFoam"
#3  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::operator==(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/boundaryFoam"
#4  void Foam::functionObjects::turbulenceFields::processField<double>(Foam::word const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
#5  Foam::functionObjects::turbulenceFields::execute() at ??:?
#6  Foam::functionObjects::timeControl::execute() at ??:?
#7  Foam::functionObjectList::execute() at ??:?
#8  Foam::Time::run() const at ??:?
#9  Foam::Time::loop() at ??:?
#10  ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/boundaryFoam"
#11  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#12  ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/boundaryFoam"
Aborted (core dumped)
Does anyone know what happened, and how this is supposed to work now? I don't see any tutorials in the current release using boundaryFoam that actually map the output or use function objects.
Thanks
KTG is offline   Reply With Quote
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 09:51
Foam::error::printStack(Foam::Ostream&) at ??:? mdhfiz OpenFOAM Running, Solving & CFD 1 September 19, 2019 10:46
Sudden contration MrAndersDk OpenFOAM Running, Solving & CFD 30 October 11, 2018 04:23
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 04:18
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
