How to access mesh/objectRegistry via codeStream in a sampleDict (v1912)? |
June 1, 2021, 06:48 |
Hello everyone,
in order to analyse boundary layer profiles on an airfoil I need to sample surface normal lines. For this purpose I tried to use codeStream in my sampleDict to automatically set the start and end points of the lines. Therefore, I need the surface normals from the mesh. My first approach to access the mesh, was the following: Code:
wallNormalEndPoint #codeStream { code #{ const IOdictionary& d = static_cast<const IOdictionary&>(dict); const fvMesh& mesh = refCast<const fvMesh>(d.db()); vector nearestP1(0, 0, 0); // only for testing vector normal(-1, 0, 0); // only for testing vector endPoint; endPoint = nearestP1 + normal; Info << "P1 = (" << endPoint.x() << " " << endPoint.y() << " " << endPoint.z() << ")" << endl; os << "(" << endPoint.x() << " " << endPoint.y() << " " << endPoint.z() << ")"; #}; //! Optional: codeInclude #{ #include "fvCFD.H" #include "fvMesh.H" #}; //! Optional: codeOptions #{ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude \ -I$(LIB_SRC)/OpenFOAM/lnInclude/ #}; //! libs: codeLibs #{ -lmeshTools \ -lfiniteVolume #}; }; Code:
pimpleFoam -postProcess -latestTime -func sample Code:
Using #codeStream at line 32 in file ".../system/sample" Using #codeStream with ".../dynamicCode/platforms/linux64Gcc7DPInt32Opt/lib/libcodeStream_ab16c0dcca50c69f8e3bea68d47adc1f7bc2dd69.so" P1 = (0 0 0) Using #codeStream at line 99 in file ".../system/sample" Using #codeStream with ".../dynamicCode/platforms/linux64Gcc7DPInt32Opt/lib/libcodeStream_51d2e298681900269ae92473d9c4ffb099161003.so" Creating new library in "dynamicCode/_51d2e298681900269ae92473d9c4ffb099161003/platforms/linux64Gcc7DPInt32Opt/lib/libcodeStream_51d2e298681900269ae92473d9c4ffb099161003.so" Invoking wmake libso .../dynamicCode/_51d2e298681900269ae92473d9c4ffb099161003 wmake libso .../dynamicCode/_51d2e298681900269ae92473d9c4ffb099161003 ln: ./lnInclude dep: codeStreamTemplate.C Ctoo: codeStreamTemplate.C codeStreamTemplate.C: In function ‘void Foam::codeStream_51d2e298681900269ae92473d9c4ffb099161003(Foam::Ostream&, const Foam::dictionary&)’: codeStreamTemplate.C:60:23: warning: unused variable ‘mesh’ [-Wunused-variable] const fvMesh& mesh = refCast<const fvMesh>(d.db()); ^~~~ ld: .../dynamicCode/_51d2e298681900269ae92473d9c4ffb099161003/../platforms/linux64Gcc7DPInt32Opt/lib/libcodeStream_51d2e298681900269ae92473d9c4ffb099161003.so #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 ? in /lib64/libc.so.6 #3 __dynamic_cast in /usr/lib64/libstdc++.so.6 #4 Foam::fvMesh const& Foam::refCast<Foam::fvMesh const, Foam::objectRegistry const>(Foam::objectRegistry const&) at ??:? #5 codeStream_51d2e298681900269ae92473d9c4ffb099161003addr2line: DWARF error: could not find variable specification at offset 2660 addr2line: DWARF error: could not find variable specification at offset 26b9 addr2line: DWARF error: could not find variable specification at offset 271d addr2line: DWARF error: could not find variable specification at offset ac91 addr2line: DWARF error: could not find variable specification at offset ac9c addr2line: DWARF error: could not find variable specification at offset b2c0 addr2line: DWARF error: could not find variable specification at offset b302 addr2line: DWARF error: could not find variable specification at offset b344 addr2line: DWARF error: could not find variable specification at offset b386 addr2line: DWARF error: could not find variable specification at offset b3b2 addr2line: DWARF error: could not find variable specification at offset b3e9 addr2line: DWARF error: could not find variable specification at offset b3f4 addr2line: DWARF error: could not find variable specification at offset b42b addr2line: DWARF error: could not find variable specification at offset b436 addr2line: DWARF error: could not find variable specification at offset 1cc1 addr2line: DWARF error: could not find variable specification at offset 1cf5 addr2line: DWARF error: could not find variable specification at offset 1d0f addr2line: DWARF error: could not find variable specification at offset 7764 addr2line: DWARF error: could not find variable specification at offset 90cd addr2line: DWARF error: could not find variable specification at offset 90e3 addr2line: DWARF error: could not find variable specification at offset 900c addr2line: DWARF error: could not find variable specification at offset 906c addr2line: DWARF error: could not find variable specification at offset 912b addr2line: DWARF error: could not find variable specification at offset 9141 addr2line: DWARF error: could not find variable specification at offset 9189 addr2line: DWARF error: could not find variable specification at offset 919f addr2line: DWARF error: could not find variable specification at offset 9205 addr2line: DWARF error: could not find variable specification at offset aa58 at dynamicCode/_51d2e298681900269ae92473d9c4ffb099161003/codeStreamTemplate.C:60 #6 Foam::functionEntries::codeStream::evaluate(Foam::dictionary const&, Foam::Istream&) at ??:? #7 Foam::functionEntries::codeStream::execute(Foam::dictionary const&, Foam::primitiveEntry&, Foam::Istream&) at ??:? #8 Foam::functionEntry::execute(Foam::word const&, Foam::dictionary const&, Foam::primitiveEntry&, Foam::Istream&) at ??:? #9 Foam::primitiveEntry::acceptToken(Foam::token const&, Foam::dictionary const&, Foam::Istream&) at ??:? #10 Foam::primitiveEntry::read(Foam::dictionary const&, Foam::Istream&) at ??:? #11 Foam::primitiveEntry::readEntry(Foam::dictionary const&, Foam::Istream&) at ??:? #12 Foam::primitiveEntry::primitiveEntry(Foam::keyType const&, Foam::dictionary const&, Foam::Istream&) at ??:? #13 Foam::entry::New(Foam::dictionary&, Foam::Istream&, Foam::entry::inputMode, int) at ??:? #14 Foam::dictionary::read(Foam::Istream&, bool) at ??:? #15 Foam::dictionary::dictionary(Foam::Istream&, bool) at ??:? #16 Foam::functionObjectList::readFunctionObject(Foam::string const&, Foam::dictionary&, Foam::HashSet<Foam::wordRe, Foam::string::hash>&, Foam::word const&) at ??:? #17 Foam::functionObjectList::New(Foam::argList const&, Foam::Time const&, Foam::dictionary&, Foam::HashSet<Foam::wordRe, Foam::string::hash>&) at ??:? #18 ? at ??:? #19 __libc_start_main in /lib64/libc.so.6 #20 ? at /home/abuild/rpmbuild/BUILD/glibc-2.26/csu/../sysdeps/x86_64/start.S:122 For me it seems like I have no access to the objectRegistry when I use codeStream in a sampleDict. :/ Am I doing something wrong or is it just not possible to access the mesh? Thanks in advance for any help or ideas. |
codestream, mesh, objectregistry, post-processing, sampledict |
Access cell values in codeStream | gomz | OpenFOAM Programming & Development | 2 | April 27, 2022 04:30 |
different results form openfoam 3.0.1 to 1912 | yuno | OpenFOAM Running, Solving & CFD | 0 | September 28, 2020 03:09 |
PROBLEMS DEFINING A LIST USING #CODESTREAM !! Help please !! | angatri_14 | OpenFOAM Programming & Development | 1 | August 21, 2020 17:16 |
Is there a way to access the gradient limiter in Fluent ? | CFDYourself | FLUENT | 1 | February 16, 2016 05:49 |
controlDict and sampleDict giving different results | Shenan | OpenFOAM Post-Processing | 2 | November 15, 2014 10:15 |
