Graphically Comparing Results in Paraview Between 2 Different Test Cases |
November 17, 2019, 10:54 |
Bren
Hi Guys,
I am having difficulty in figuring out how to graphically compare pressure or velocity field differences between 2 similar cases from Openfoam in Paraview. The cases have slightly different models and I am trying to graphically see where the flow field changes between them rather than comparing with images from slices etc. Is there any way in Paraview to compare different case results? Thanks Bren |
November 17, 2019, 11:04 |
Torsten Schenkel
Rep Power: 12 |
Are the different cases on the same mesh? If yes, you can load both cases at the same time and use the pythonCalculator or Calculator filter to calculate the relative difference between the two cases at each cell (or point). You can then visualise that difference. T |
November 17, 2019, 11:14 |
Bren
Hi tschenkel
Thanks for your reply. Some of the cases are at different velocities but for other cases, where the model has changed, I guess from your reply, that if the mesh changes at all, they can't be compared? I am familiar with Fluent where two cases could be opened and you could look at a delta pressure or velocity flow field rather than just on an xy graph. Is there any way to achieve something similar? Thanks again Bren |
[General] ParaView is not reading the results | bussaco8 | ParaView | 1 | May 18, 2022 13:26 |
LTS based Lagrangian particle solver and test cases | ulli | OpenFOAM Announcements from Other Sources | 17 | April 13, 2021 08:06 |
Comparing Air numerical results with water experimental results | cristian2009es | Main CFD Forum | 1 | July 2, 2014 18:11 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
Standard CFD test cases? | Damon Qualski | Main CFD Forum | 1 | April 10, 2003 14:10 |
