Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
pressure drop for periodic flow
Old   December 25, 2019, 15:25
Default pressure drop for periodic flow
Kaazem
Kaazem_RA is on a distinguished road
Hi all
I simulated fully developed flow using openfoam. I need to calculate pressure drop. The problem is that the pressure boundary condition at the inlet and outlet are cyclic and therefore pressures are the same at this boundaries. Is there any way to calculate actual pressure and subsequently pressure drop?
an early reply would be highly appreciated
Kaazem_RA is offline   Reply With Quote
Old   December 26, 2019, 01:33
Kaazem
I should mention that i added a source term in the momentum equation via fvoption.
Old   December 26, 2019, 07:02
Santiago Lopez Castano
Santiago is on a distinguished road
so you impose the pressure gradient (drop)....
Santiago is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
Boundary conditions for flow in nozzle kgevers FLUENT 0 July 26, 2015 12:46
Mass flow rate prediction of Purge control valve using set pressure drop enr_venkat CFX 11 February 27, 2014 11:30
Non-steady flow simplified for use in Vissim steamerandy Main CFD Forum 0 October 31, 2011 21:08
