Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Probes - Functionobjects- surfaceScalarField
Old   December 30, 2019, 11:40
Default Probes - Functionobjects- surfaceScalarField
Kumaresh
Kummi is on a distinguished road
Send a message via Yahoo to Kummi
Hello Foamers,
My question might be quite basic. I dont find any appropriate thread or may be I couldn't figured it out properly about this topic.
In my case (OF211), volScalarFields such as Temperature, Ycoal, Ychar, K, rho have been calculated using function objects based on probes (as shown below).
functions
oven_hope
type probes;
functionObjectLibs ("libsampling.so");
outputControl timeStep;
outputInterval 50;
region oven;
probeLocations
(0.1 1.0 0.05) // at wall
(0.15625 1.0 0.05) // 1/4 distance
(0.2125 1.0 0.05) //1/2 distance
(0.26875 1.0 0.05) // 3/4 distance
(0.325 1.0 0.05) // centre
fields
(T Ycoal Ychar phiGas K rho);
but the surfaceScalarField "phiGas" couldn't be predicted based on probes.
Kindly someone share ideas about it please.
Thank you
Kummi is offline   Reply With Quote
Old   December 30, 2019, 17:27
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
What do you actually mean by 'couldn't be predicted based on probes.'? Supposedly wrong result? Error?
HPE is offline   Reply With Quote
Old   December 30, 2019, 18:56
Kumaresh
Dear HPE, Thank you for your response.
"phiGas" values at all probes ends up with 0 (no changes)
Old   December 31, 2019, 01:19
HPE
HPE's Avatar
Two quick things out of my head:
- probes return only cell values without interpolation, so the probes at four probe locations above should return the same value if they are inside the same cell.
- phiGas results might be the boundary values, which might be zero at the wall.
Old   December 31, 2019, 02:09
Kumaresh
Hello HPE,
Yes, probes return cell values, at 5 probe locations mentioned above with 5 different positions along X, I got graphs as shown in the attachment.
~ And about "phiGas" - I'm confused. This is how, phiGas is declared:
https://github.com/OpenFOAM/OpenFOAM...reactingOneDim
//- Total gas mass flux released [kg/m2/s]
surfaceScalarField phiGas_;
phiGas_ == dimensionedScalar("zero", phiGas_.dimensions(), 0.0);
phiGas_
IOobject
"phiGas",
time().timeName(),
regionMesh(),
IOobject::NO_READ,
IOobject::AUTO_WRITE
regionMesh(),
dimensionedScalar("zero", dimMass/dimTime, 0.0)
Kindly share if you have any ideas - as how to predict phiGas.
Thank you HPE for your valuable time ^^
Upwind Gradient Not Recognizing surfaceScalarField MajidHagh OpenFOAM 2 October 30, 2019 11:58
Error in probes functions!!! Jingxue Wang OpenFOAM Running, Solving & CFD 9 November 25, 2017 09:21
probes function not working in Openfoam 2.1.1 nandiganavishal OpenFOAM 7 July 26, 2012 11:06
OpenFOAM v1.6 & OpenMPI & functionObjects bruce OpenFOAM Bugs 7 December 16, 2011 14:37
OpenFOAM v1.6 & OpenMPI & functionObjects bruce OpenFOAM Running, Solving & CFD 1 August 7, 2009 13:15
