January 13, 2020, 06:24 |
wallShearStress
Shai Aser
Rep Power: 10 |
I hope someone will be able to clarify the following; wallShearStress is calculated as R*n, where R is the stress tensor and n is the surface normal. When you export wallShearStress on a patch openfoam gives you the data on mesh points. But points are shared by several faces, which may have different normal orientations. So how do you make sense of the values you get? Cheers, |
Finding wallShearStress in dbnsTurbFoam | BSengupta | OpenFOAM | 4 | October 21, 2019 21:17 |
Error computing wallShearStress with simpleFoam | sita | OpenFOAM Post-Processing | 6 | November 4, 2018 15:02 |
wallShearStress vs. force functionObject | pad | OpenFOAM Post-Processing | 2 | March 8, 2016 11:24 |
why does 'sample' do this? wallShearStress question | CHARLES | OpenFOAM Post-Processing | 0 | August 7, 2013 19:30 |
wallShearStress VS wallGradU | bigrock | OpenFOAM Post-Processing | 0 | July 2, 2013 05:54 |
