Power Spectral Density for velocity with postProcessing "noise" |
February 10, 2020, 05:03 |
niewiemnic
Rep Power: 8 |
I am searching info for the power spectral density of velocity (uu, boths in the direction of stream) in the phase of postprocessing. It is clear that I can get results about PSD of pressure (fluctuation?) with e.g. Code:
mpirun -np 16 noise -dict system/noiseDict-point -parallel My simulation is an aeroacoustic calculation about rod-airfoil configuration and the points on which I will get results are nearby rod and airfoil. Does someone have any idea for that? |
February 10, 2020, 10:45 |
I guess I found the answer...
niewiemnic
Rep Power: 8 |
At first I collect the info about velocity fields with controlDict
probes { type patchProbes; libs ("libsampling.so"); writeControl timeStep; timeStart 2.0; patch cylinder; probeLocations ( (0.4 0.2 0.08) // E (-0.4 0.2 0.08) // W (0.07 0.2 0.3) // N (0.07 0.2 -0.3) // S ); fields (U p forces:force Curle); } Code:
pointNoiseCoeffs { windowModel Hanning; files ( "postProcessing/probes/0.1/U" "postProcessing/probes/0.1/p" "postProcessing/probes/0.1/Curle" ); ... } |
March 30, 2020, 16:07 |
niewiemnic
Rep Power: 8 |
Unfortunately it doesnt work for U... Nobody knows how can I do postprocessing the PSD of velocity?
June 25, 2020, 09:30 |
Small test for validation of psd
#4 | |
Kossivi GOKPI
Rep Power: 15 |
Hello spalartallmaras,
I'm working currently the OF version18+ in order to use psd utility. Everything is working quite good for pressure PSD calculation. Nevertheless I'm looking for a samll test case with result with other sofware for example Fluent to compare with what I get with OF. I would like to know if you have a test case to validate the result of OF. Kind regards, Kossivi. Quote:
Thanks in advance, Kossivi. |
Display Modes | |
power spectrum density | hosseini | CFX | 1 | August 31, 2017 07:43 |
power spectral density | vetnav | Main CFD Forum | 8 | September 3, 2010 14:28 |
power spectral density | cfd_newbie | FLUENT | 1 | December 10, 2007 00:53 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 08:23 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
