Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
How to calculate the LES turbulent kinetic erengy in OpenFOAM
Like Tree3Likes
  • 1 Post By wangziyang
  • 1 Post By cjc96
  • 1 Post By Luiz
Old   February 25, 2020, 01:56
Post How to calculate the LES turbulent kinetic erengy in OpenFOAM
王子阳
wangziyang is on a distinguished road
hi
i recently want to calculate the turbulent kinetic erengy using LES,
when i search on the net, i only search the formula: k= 0.5((u')^2+(v')^2+(w')^2)
where,u'=u-umean,v'=v-vmean,w'=w-wmean
i think this formula is uncorrect,but i can't find how to calculate LES TKE in openfoam
help!
best wishes!
ziwang
Светлана likes this.
wangziyang is offline   Reply With Quote
Old   February 27, 2020, 07:57
Conor Crickmore
cjc96 is on a distinguished road
Hey!
This is asked quite a lot on the forum, you'll probably find a fair few discussions about if you were to type in "LES TKE CFD-Online" into Google. Your formula for Turbulent Turbulent Kinetic Energy is (more or less) correct.
I've recently posted a thread where I was working on a function to output the ratio of resolved/total TKE for my own LES work, see here.
The quick version of which is that the 'R' post-processing function will provide you with the sub-grid Reynolds Stress Tensor, and the 'UPrime2Mean' calculation in the 'fieldAverage' function will provide you with the resolved Reynolds Stress Tensor, where:
k = \frac{1}{2}tr(R)
so your total Turbulent Kinetic Energy is:
k_{total} = k_{sub-grid} + k_{resolved} = \frac{1}{2}tr(R) + \frac{1}{2}tr(UPrime2Mean)
Hopefully this and the links provided should be enough to see you through!
Conor Crickmore
PhD Researcher in Automotive Aerodynamics
Aeronautical and Automotive Engineering
Loughborough University
LE11 3TU
cjc96 is offline   Reply With Quote
Old   August 27, 2020, 16:51
Luiz Oliveira
Luiz is on a distinguished road
Since someone might be as lazy as myself, here goes the code that adds the totalTKE into account:
totalTKE
    type            coded;
    libs            ("libutilityFunctionObjects.so");
    name            totalTKE;
    executeControl    timeStep;
    writeControl    writeTime;
    // timeStart        0;
    // timeEnd        0;
    enabled            true;
    Total Turbulent Kinect Energy Evaluation
        ** Requires fieldAverage Function to Obtain UPrime2Mean**
            ** Resolved Reynolds Stress Tensor
        ** Requires turbulenceFields Function to Obtain R**
            ** Subgrid Reynolds Stress Tensor
    codeExecute
        static autoPtr<volScalarField> totalTKE;
        if
            mesh().foundObject<volSymmTensorField>("UPrime2Mean")
            mesh().foundObject<volSymmTensorField>("turbulenceProperties:R")
            mesh().foundObject<volScalarField>("totalTKE") == 0
            Info << "Turbulent Kinect Energy:" << endl;
            Info << "    Initialising" << endl;
            Info << "    Calculating" << nl << endl;
            totalTKE.set
                new volScalarField
                    IOobject
                        "totalTKE",
                        mesh().time().timeName(),
                        mesh(),
                        IOobject::NO_READ,
                        IOobject::AUTO_WRITE
                    mesh(),
                    dimensionedScalar
                        "totalTKE",
                        dimensionSet(0,2,-2,0,0,0,0),
                        0
            const volSymmTensorField& R = mesh().lookupObjectRef<volSymmTensorField>("turbulenceProperties:R");
            const volSymmTensorField& UPrime2Mean = mesh().lookupObjectRef<volSymmTensorField>("UPrime2Mean");
            volScalarField& totalTKE = mesh().lookupObjectRef<volScalarField>("totalTKE");
            totalTKE = (0.5 * tr(R)) + (0.5 * tr(UPrime2Mean));
            totalTKE.write();
        else if
            totalTKE.write();
        else
            Warning << endl
                    << "    Unable to Calculate Turbulent Kinect Energy" << endl
                    << "    UPrime2Mean and/or R Unavailable" << endl
                    << "    Enable fieldAverage and turbulenceFields Functions" << nl << endl;
Note that this most be in system folder and called by controlDict.
The only changes from cjc96 function are the referencing to R (from R to turbulenceProperties:R) and the calculation itself. I checked function results with some literature data available and it seems to yield adequate values.
oswald likes this.
Luiz Oliveira
MSc Researcher in Environmental Fluid Dynamics
Federal University of Mato Grosso do Sul
Luiz is offline   Reply With Quote
tke les
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 14:24
How to calculate turbulent kinetic energy at first grid point in SST k-o dinhanh Main CFD Forum 1 December 19, 2016 09:54
OpenFOAM LES capability questions siw OpenFOAM Running, Solving & CFD 3 January 6, 2015 08:50
Subgrid Turbulent Kinetic Energy in LES saqure ANSYS 3 September 7, 2012 16:44
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
