postProcess -field U -func mag, Why it gives error? |
April 9, 2020, 12:39 |
Hi guys.
Ok, I already know that I can use the following code and compute the mag of U easily: Code:
postProcess -func "mag(U)" Code:
postProcess -fields "(p U)" -func wallShearStress Code:
postProcess -field U -func mag Code:
Time = 1 Reading fields: volVectorFields: U Executing functionObjects --> FOAM Warning : functionObjects::mag mag cannot find required object <fieldName> of type volScalarField --> FOAM Warning : functionObjects::mag mag cannot find required object <fieldName> of type surfaceScalarField --> FOAM Warning : functionObjects::mag mag cannot find required object <fieldName> of type volVectorField --> FOAM Warning : functionObjects::mag mag cannot find required object <fieldName> of type surfaceVectorField --> FOAM Warning : functionObjects::mag mag cannot find required object <fieldName> of type volSphericalTensorField --> FOAM Warning : functionObjects::mag mag cannot find required object <fieldName> of type surfaceSphericalTensorField --> FOAM Warning : functionObjects::mag mag cannot find required object <fieldName> of type volSymmTensorField --> FOAM Warning : functionObjects::mag mag cannot find required object <fieldName> of type surfaceSymmTensorField --> FOAM Warning : functionObjects::mag mag cannot find required object <fieldName> of type volTensorField --> FOAM Warning : functionObjects::mag mag cannot find required object <fieldName> of type surfaceTensorField --> FOAM Warning : functionObjects::mag mag failed to execute. Cheers & Stay Healthy!
Learn OpenFOAM in Persian SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member Complex Heat & Flow Simulation Research Group If you can't explain it simply, you don't understand it well enough. "Richard Feynman" |
April 9, 2020, 14:08 |
Yan Zhang
Rep Power: 11 |
You need a configuration file in the system directory, like this:
https://github.com/OpenFOAM/OpenFOAM...ing/fields/mag change the <fieldName> to U and then: Code:
postProcess -func mag -field U
https://openfoam.top |
April 9, 2020, 14:16 |
#3 | |
But I already have the configuration file in the OpenFOAM caseDicts directory. However, I copied the file into my system folder too: Code:
foamGet mag Cheers
April 9, 2020, 14:18 |
Yan Zhang
Rep Power: 11 |
Don't forget to change the <fieldName> to U
April 9, 2020, 14:21 |
Yea, that did the trick. Thanks!
However, I get two warnings whenever I try to compute mag(U) field using any method. Do you know why? Code:
Time = 1 Reading fields: volVectorFields: U Executing functionObjects --> FOAM Warning : functionObjects::mag mag cannot find required object U of type volScalarField --> FOAM Warning : functionObjects::mag mag cannot find required object U of type surfaceScalarField functionObjects::mag mag writing field: mag(U)
April 9, 2020, 14:22 |
Yan Zhang
Rep Power: 11 |
Me too. Just forget it.
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
