March 6, 2020, 06:57 |
Reconstruct created field
pardoa
Rep Power: 7 |
Hi everyone,
I have defined a new function object to calculate the hydraulic head from the values of water pressure at the bottom of my problem domain. Since the area that I'm simulating is too big, I have split it into several pieces so as to run it in parallel using several cores. The computation of the heads works very well at each processor but once I reconstruct the domain, the values of head are not merged as it happens to the rest of calculated fields. Can anyone give me a hand on this? Thanks! Alvaro |
March 6, 2020, 08:11 |
#2 | |
pardoa
Rep Power: 7 |
This is the object function I wrote:
I have checked the reconstructPar code and apparently it is not possible to reconstruct patchScalarFields but only volumes. Does anyone face this issue before? Many thanks in advance. Álvaro |
[SOWFA] NREL SOWFA ABLTerrainSolver tutorial problem | cico0815 | OpenFOAM Community Contributions | 36 | February 3, 2022 11:54 |
funkySetBoundaryFields - Manipulation of existing field | jhertel | OpenFOAM Pre-Processing | 16 | May 18, 2020 06:32 |
decomposePar fails: supplied field size is not equal to target patch size | AndrewF | OpenFOAM Pre-Processing | 0 | September 11, 2016 02:55 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
