Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Query:: Extracting "Cp" in solidThermophysicalModel
Old   March 18, 2020, 12:28
Question Query:: Extracting "Cp" in solidThermophysicalModel
Kumaresh
Kummi is on a distinguished road
Send a message via Yahoo to Kummi
Hello all,
In my work, I need to plot Cp value. While referring the threads here, I came across the builtin package - "specificHeat.tar.gz". Credits and thanks to Mr. Bruno Santos.
how can see Cp values?
With this, I altered the thermophysical properties for my solid model as attached here. COMPILED well and GOOD in OpenFOAM - 2.1.1.
While running the case file, I came up with one technical error as follows:
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/kummijai/OpenFOAM/CASES/1/constant/solidThermophysicalProperties at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
Apparently, the error is all about the absence of solidThermophysicalProperties file in constant folder. The image in the attachment clearly shows, solidThermophysicalProperties file is not kept under constant file directly. For pyrolysis modelling in OpenFOAM, the location of solidThermophysicalProperties file is set- as like,
Case_File/constant/oven/solidThermophysicalProperties
Any ideas how to eliminate this technical error ?
Kindly suggest me.
Thank you
Kummi is offline   Reply With Quote
Old   March 19, 2020, 05:12
Kumaresh
Dear Foamers,
In this problem, there are two different regions named furnace and oven. (kind of multi-region solver)
How can I get the Cp value from my (solid)thermophysicalProperties in constant/region_folder/solidThermophysicalProperties. My solidThermophysicalProperties file looks like this:
thermoType
solidMixtureThermo<reactingSolidMixture<constSolid Transport<constSolidRad<constSolidThermo<constRho> >>>>;
solidComponents
coal char
coalCoeffs
transport
K 0.035;
radiation
sigmaS 0.0;
kappa 0.0;
emissivity 0.0;
thermodynamics
Cp 1052.4;
Tref1 380;
Tref2 1800;
Hf -1.74e6;
density
rho 1329;
With this, the Cp value can be extracted using functionObjects as:
heatCp
type cellSource;
functionObjectLibs ("libfieldFunctionObjects.so");
enabled true;
outputControl timeStep;
region oven;
outputInterval 1;
log true;
valueOutput false;
source all;
sourceName none;
operation volAverage;
fields
heatCp
How to access the above (solid)thermodynamics dictionary by eliminating above error, where Cp value can be extracted ??
how to query node coordinates? phsieh2005 OpenFOAM Post-Processing 3 November 26, 2018 20:13
query for variable cell limit don6alfonso OpenFOAM Programming & Development 0 October 2, 2017 03:43
Working with Python: Query of through-plane flow of multiple clips in one plot PedroInvierno EnSight 8 April 10, 2017 09:23
Extracting data along polylines in transient solution blidblid CFX 1 July 27, 2016 02:05
Query for SU2 version through script/code neetin SU2 1 June 21, 2016 21:20
