postProcess Utility: icoFoam -noFunctionObjects Why?How? |
November 4, 2016, 06:04 |
#1 | ||
Teresa
Rep Power: 10 |
Dear Forum Users,
my goal is to get the wallShearStress of my icoFoam (openFoam 4.0) case. For simpleFoam it is documented in the Userguide: simpleFoam -postProcess -func wallShearStress So I tried this: icoFoam -postProcess -func wallShearStress Outcome: Quote:
I get this Quote:
Any Ideas? Kind regards, Teresa |
November 5, 2016, 03:21 |
Arsalan
Rep Power: 11 |
Simply run application
wallShearStress Arsalan. |
November 5, 2016, 03:34 |
#3 | |
Teresa
Rep Power: 10 |
Hi Arsalan,
this application does not exist in openFoam 4.0. This is what you get if you try it: Quote:
Teresa |
November 13, 2016, 12:42 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: For situations where the solver isn't needed for post-processing, there is the postProcess utility, e.g.:
postProcess -func wallShearStress The closest would be to switch to pisoFoam, for which you need to update "fv*" files in "system" and add "turbulenceProperties" in the folder "constant".
November 13, 2016, 13:32 |
Teresa
Rep Power: 10 |
Thank you for you help.
I have one more question regardning you tipp: Should I calculate the hole case again oder just use pisofoam for postprocessing the icofoam case? Kind regards, Teresa |
November 13, 2016, 16:07 |
Bruno Santos
Rep Power: 128 |
Quick answer: It should work without having to simulate everything again... although I am a bit concerned about the value you've used for "nu" in the "transportProperties" file.
I say this because the icoFoam solver is mostly a simple/basic solver for demonstrating how things work and it doesn't account for all of the physics... which may lead to people to not properly adjust the "nu" value either and instead use the default values from the tutorial cases. |
November 14, 2016, 03:43 |
Teresa
Rep Power: 10 |
Thanks again!
What physics are you are thinking of? I chose icoFoam because my case has a transient, laminar flow of an incompressible fluid. I usually use normalization so I change the kinematic velocity to reflect the Reynolds-Number. Greetings, Teresa |
November 14, 2016, 17:10 |
#8 | |
Bruno Santos
Rep Power: 128 |
If you only want to calculate wall shear stress, it should work just fine. Because from what I've looked up on the old code in 2.3.x, wall shear stress is essentially: Code:
const volSymmTensorField Reff(-nu()*dev(twoSymm(fvc::grad(U_)))); wallShearStress.boundaryField()[patchI] = ( -mesh.Sf().boundaryField()[patchI] /mesh.magSf().boundaryField()[patchI] ) & Reff.boundaryField()[patchI]; Essentially my concern is that if you needed to calculate other properties that depend on how the flow was modelled, pisoFoam accounts for more details that icoFoam doesn't. If you compare the source code of the two solvers, you'll see what I mean. |
July 26, 2023, 02:41 |
#9 | |
mhy
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
icoFoam floating point exception (8) | leizhao512 | OpenFOAM Running, Solving & CFD | 7 | November 1, 2018 11:43 |
postProcess functionality in openFOAM 4 | bullmut | OpenFOAM Post-Processing | 23 | July 21, 2017 09:11 |
Something doens't work with wallHeatFlux utility or externalWallHeatFluxTemperat BC!! | zfaraday | OpenFOAM Post-Processing | 0 | February 5, 2015 16:47 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
