Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
How to extract the data of all cells in the domain
Like Tree3Likes
Old   November 21, 2020, 14:20
zhangyan's Avatar
Yan Zhang
zhangyan is on a distinguished road
Originally Posted by Bodo1993 View Post
Hi zhangyan,
I am wondering if foam2Columns works for OpenFOAM v6. I tried to compile the code with wmake but I got the below error.
Making dependency list for source file foam2Columns.C
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam6/src/finiteVolume/lnInclude -I/opt/openfoam6/src/meshTools/lnInclude -I/opt/openfoam6/src/sampling/lnInclude -I/opt/openfoam6/src/lagrangian/basic/lnInclude -IlnInclude -I. -I/opt/openfoam6/src/OpenFOAM/lnInclude -I/opt/openfoam6/src/OSspecific/POSIX/lnInclude   -fPIC -c foam2Columns.C -o Make/linux64GccDPInt32Opt/foam2Columns.o
foam2Columns.C: In function ‘int main(int, char**)’:
foam2Columns.C:109:21: error: ‘fileType’ has not been declared
                     fileType::directory
/opt/openfoam6/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt32Opt/foam2Columns.o' failed
make: *** [Make/linux64GccDPInt32Opt/foam2Columns.o] Error 1
Hi Bodo,
You may try to replace
fileType::directory
with
fileName::Type::DIRECTORY
https://openfoam.top
zhangyan is offline   Reply With Quote
Old   November 23, 2020, 17:53
Bodo1993 is on a distinguished road
Hello zhangyan,
Thanks a lot. It works now.
I have noticed that you also contributed to "conditionalAverage", I am wondering if I can ask you about it here.
Looking forward to hearing from you.
Bodo1993 is offline   Reply With Quote
Old   November 25, 2020, 08:49
zhangyan's Avatar
Yan Zhang
Hello zhangyan,
We are open to questions. Please go to the right place.
Old   November 26, 2020, 13:25
Thanks. I opened a thread here: conditionalAverage Function Object
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 90 October 3, 2019 08:01
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 10 August 5, 2019 20:18
cellZone not taking all the cells inside rahulksoni OpenFOAM Running, Solving & CFD 6 January 25, 2019 01:11
[ICEM] Error in mesh writing helios ANSYS Meshing & Geometry 19 January 8, 2019 11:56
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
