-   OpenFOAM Post-Processing (https://www.cfd-online.com/Forums/openfoam-post-processing/)
-   -   Surface VTK crinkle cut (https://www.cfd-online.com/Forums/openfoam-post-processing/227873-surface-vtk-crinkle-cut.html)
EnigmaFluids June 12, 2020 17:22
Hello, I am completing LES simulations on a jet in OpenFOAM 6.
Since I must collect a lot of temporal data, I am using the "#includeFunc surfaces" to save vtk cutting planes during run time so I can use paraview to generate visualisations. However, a cutting plane will decompose my structured hex mesh into a series of tets. This will similarly happen in paraview when taking a slice. However! If you take a crinkle cut/slice in paraview then the mesh is maintained.
I am wondering if there is a way to make the "surfaces" func use produce a crinkle cut vtk file instead of the regular cutting plane file.
Thanks!
olesen June 15, 2020 06:11
Thanks!
No way that I can think of, but interesting idea to discuss. I've opened an issue:
https://develop.openfoam.com/Develop.../-/issues/1728
