Exporting results in x,y,z
Hello All,
Can anyone tell me how to export my pressure field into an x,y,z format instead of in a list according to the mesh? Also, is it possible to convert/export my surface mesh into an x,y,z format? Many thanks, Conor |
- Pressure is a scalar quantity; therefore, there won't be three components of first-order tensor to output. - Could you please elaborate what you meant by the surface mesh? OF does not produce a surface mesh, like STL, per se. But you can extract surface meshes from selected patches by using surfaceMeshExtract utility. - If you want to extract such surface meshes, could you tell me what you meant by x,y,z data? I assume it is raw csv file - no header, no parentheses? I don't remember any off-the-shelf application for this, but in OpenFOAM context the option name is `raw`. May be surfaceMeshExport, or surfaceMeshConvert utilities may help. - Also you can perform this action with ParaView: as asked here. |
Thanks for your reply, HPE.
Let me phrase the question better. I would like to know how to get the x,y,z locations of all of those scalar quantities, or if it is possible. Thanks, Conor |
Sure: writeCellCentres function object.
postProcess -func writeCellCentres -latestTime The order of the content of these fields corresponds the order of the pressure field. |
Thank you HPE,
This is very helpful. One last question: Is it possible to run this utility on one patch only? I am trying to extract a pressure field from a foil surface. Thanks, Conor |
