paraFoam command gives an error
Hi all
I am running both OpenFOAM 4.1-extend and 6.0 on Ubuntu 18.04. When I run a case via of6 and execute paraFoam, everything works as normal. However, when I run a case via of4 and execute paraFoam, I get the error Code:
Cannot use ParaView reader module library (PVFoamReader) Thanks so much! |
What is wrong with using the regular builtin OpenFOAM reader? Apart from some face/cell sets (which you can convert with foamToVTK) it handles things quite well. You may have to skip the 0/ directory if you have lots of #include, code stream etc, but that is to be expected.
The only place where the additional special-purpose readers might be useful is for diagnosing complicated blockMeshDict. Otherwise I just use the following: Code:
alias parafoam='touch log.foam; paraview log.foam' |
Created temporary 'damBreak.foam' Quote:
sudo apt-get install paraview ?
More specifically, at the end of the bashrc file I have Code:
alias of6='source /opt/openfoam6/etc/bashrc' |
I meant that you can use your system paraview. Eg, on my ubuntu system Code:
$ which paraview Do neither of these work? |
