June 12, 2020, 17:22 |
Surface VTK crinkle cut
Graham
Rep Power: 8 |
Hello, I am completing LES simulations on a jet in OpenFOAM 6.
Since I must collect a lot of temporal data, I am using the "#includeFunc surfaces" to save vtk cutting planes during run time so I can use paraview to generate visualisations. However, a cutting plane will decompose my structured hex mesh into a series of tets. This will similarly happen in paraview when taking a slice. However! If you take a crinkle cut/slice in paraview then the mesh is maintained. I am wondering if there is a way to make the "surfaces" func use produce a crinkle cut vtk file instead of the regular cutting plane file. Thanks! |
June 15, 2020, 06:11 |
#2 | |
Mark Olesen
Rep Power: 40 |
No way that I can think of, but interesting idea to discuss. I've opened an issue: https://develop.openfoam.com/Develop.../-/issues/1728 |
openfoam, postprocessing, surfaces, vtk |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
How To Create Fowcs William Hawkings Surface in Fluent? | marinkobezu | FLUENT | 7 | October 25, 2018 10:51 |
[DesignModeler] Problem with body cut using surface extension! | malekan.cfd | ANSYS Meshing & Geometry | 3 | December 22, 2017 05:08 |
[snappyHexMesh] Snap Precision to a STL Surface | malaboss | OpenFOAM Meshing & Mesh Conversion | 16 | July 26, 2013 01:44 |
to mesh a surface with cut | nabeel mohsin | FLUENT | 0 | January 6, 2005 01:43 |
