Paraview doesn't allow adjusting opacity
Hi all,
I came across a weird issue in paraview when doing visualisation. I was trying to achieve semi-transparent effect by adjusting opacity level (Properties panel -> Styling -> Opacity), however the entire visual would disappear as long as opacity is not 1. For example, the whole layer would disappear if I set Opacity to to 0.5 or even 0.99, and the layer would reappear as 100% opaque if I change Opacity level back to 1. Apart from this, everything else works perfectly. I assume it's a problem with my environment / graphic or a paraview setting I overlooked? Has anyone experienced this problem before. I appreciate you help very much! Regards, Huanghai |
thats a strange behaviour, never encountered.
there is paraview forum from the developers, i think you should contact them, if solution found pls post the link here too. |
Turned out it's a graphic driver issue. I installed the correct GPU driver following this page https://www.mvps.net/docs/install-nv...-beaver-linux/ and the issue went away. |
