Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Force output control help
Old   July 22, 2020, 05:26
Default Force output control help
TWB
quarkz is on a distinguished road
I'm using the force file to output the forces on the airfoils:
forces_total
    type            forces;
    libs            (forces);
    writeControl    time;
    writeInterval   0.001;
    log             false;
    patches
		"(front|back)"
    rho             rhoInf;
    rhoInf          1.2;
    CofR            (0.25 0 0);
However, I'm not able to control how frequently the file is written. I want it to be written e.g. every 0.001 simulated sec.
But it seems that it's written out every time step.
Is this possible? If not, what's the purpose of writeControl?
Hope to clarify this
quarkz is offline   Reply With Quote
Old   July 22, 2020, 06:47
sreekanth
neko2650 is on a distinguished road
You can change the frequency of writing the output in the beginning of controlDict file "writeInterval" line and later you can call the "writeIterval" option in your functions
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     interFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         10;
deltaT          0.01;
writeControl    adjustableRunTime;
purgeWrite      0;
writeFormat     binary;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
adjustTimeStep  yes;
maxCo           0.5;
maxAlphaCo      0.5;
maxDeltaT       1;
functions
    forces
        type                forces;
        libs                ("libforces.so");
        writeControl        timeStep;
        writeInterval          1;
        patches             (walls);
        rho                 rhoInf;
        log                 true;
        rhoInf              1;
        CofR                (0 0 0);
neko2650 is offline   Reply With Quote
Old   August 31, 2020, 23:07
TWB
Ya I changed it but it doesn't seem to be working. Are you sure this works?
Old   September 1, 2020, 04:36
sreekanth
These are the enumeration which can be given to writeControl present in functions as per OF-7.
 adjustableRunTime
clockTime
cpuTime
none
outputTime
runTime
timeStep
writeTime
As per your requirement writeControl present in the functions has to look up for the main run time write sequence with write interval of 0.001. Hence change the enumerator from timeStep to writeTime. I hope this will work.
ActuatorDiskExplicitForce in OF2.1. Help be_inspired OpenFOAM Programming & Development 10 September 14, 2018 11:12
ABAQUS Spring force Output nolanb13 Structural Mechanics 5 September 11, 2018 11:12
output force instead of Cd in console ceanwang SU2 3 August 26, 2018 00:03
drag force output file on parallel computing Jackie FLUENT 2 January 9, 2012 22:55
Fundamental output format control of field values and time dbxmcf OpenFOAM 1 January 12, 2011 10:50
