Anand
Rep Power: 6 ![]() |
Can someone help me reg. how to view age of air, PPD and PMV values in paraview?
Steven Forrester
Rep Power: 0 ![]() |
Yes, how do we view the results. Also why can't this run in parallel?
Steven Forrester
It looks there maybe a bug, on the converged time step the PMV and PPD don't show up in paraview, go one time step back and they are there. Depending on the size of your time step this may not be make that big of a difference.
Because I can't figure out how to run it in parallel I'm essentially post processing the results by running the converged domain with the comfort added in, then I can save more time steps on this run, so not a problem. I don't know about the boundary conditions, I'm just using the ones from the tutorial. I have not found any documentation on them, because the field values should be calculated from the air speed, air temperature and mean radiant temperature I would think they should be zero gradient. |
paraview 4.2, pmv, ppd |
Display Modes | |
trying to calculate PMV, PPD and PD in fluent using UDF | chunying | Fluent UDF and Scheme Programming | 8 | February 1, 2025 07:44 |
sharing code to calculate PMV, PPD and PD in fluent using UDF | simon02200059 | Fluent UDF and Scheme Programming | 2 | June 24, 2019 01:02 |
UDF for PMV and PPD | lcbarreto | Fluent UDF and Scheme Programming | 4 | February 7, 2019 06:44 |
PPD & PMV value | Tanty Ali | CFX | 6 | April 3, 2018 05:40 |
