Comparision of plateHole solution with analytical solution |
August 25, 2020, 15:58 |
Rishav Kumar
Rep Power: 5 |
I am a newbie who has just started to learn openFoam 2 weeks ago. I have installed Foam Extend 4.0 on Ubuntu 20.04. I am going through the plateHole problem according to the user guide that comes with the foam-extend.
I have run the code and want to compare my solution with the analytical solution. The user guide suggest me to go the sample utility which uses a sampleDict dictionary located in the system directory. I do not find any such file in system directory instead there is another folder called analyticalPlateHole in the plateHole folder. I do not know how to use it. I faced similar solution while going through the user guide and I think that the guide is different in many ways and doesn't comply with the foam extend 4.0. Is there any latest user guide available? or Can anyone suggest how to compare the solution with analytical solution? |
UDF for Automatic Solution Initialization for previous case data file | gartz89 | Fluent UDF and Scheme Programming | 6 | March 30, 2020 07:38 |
Comparison between analytical and numerical solution.. | virendra_p | Main CFD Forum | 1 | September 22, 2014 14:24 |
Analytical solution to the 3d Laplace equation | Chrys Correa | Main CFD Forum | 4 | September 11, 2000 18:50 |
Analytical solution for radiation | Chrys Correa | Main CFD Forum | 6 | November 25, 1999 09:59 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
