September 22, 2020, 03:36 |
foamCleanTutorials
Rep Power: 6 |
Hi,guys.
I have a little problem, I'm running foamCleanTutorials in opt/tutorials,Is there a problem with my openfoam,When I use it later。 |
September 22, 2020, 05:14 |
Petros Ampatzidis
Rep Power: 7 |
I am not quite sure that I understand the question but the foamCleanTutorials just cleans the case, meaning that it removes the solution, mesh and processors in the current case folder. Nothing will affect your OpenFOAM installation. However, you might want to consider copying the tutorials folder in a run directory. This will reduce your anxiety about deleting something or messing up the files. I don't know which OpeFOAM distribution you are using but for the ESI and Foundation the following will work: Code:
cd $HOME/OpenFOAM/<USER>/ mkdir -p $FOAM_RUN cd $FOAM_RUN cp -r $FOAM_TUTORIALS . Petros |
September 22, 2020, 21:18 |
Thanks to Petros
#3 | |
Rep Power: 6 |
Bro, thank you very much. I didn't expect to get a reply so soon. I will consider your suggestion carefully. |
foamcleantutorials |
foamCleanTutorials recovery?! | nore5 | OpenFOAM Running, Solving & CFD | 1 | September 1, 2021 01:59 |
[OpenFOAM] Problems opening wigleyHull case in ParaView | Ron de Vos | ParaView | 18 | September 12, 2015 14:46 |
