Unable to read the Temperature field with Paraview |
September 11, 2020, 07:40 |
Francesco Latella
Rep Power: 6 |
Hi guys, I'm translating a solver with a conjugate heat transfer method implemented in interFoam from the version 2.2.1 of OF to the 7. I did it, and I was also able to run a test case, but when I try to visualize the result, I get an error by paraview for every processor, I show you just for one
ERROR: In /home/ag600/OpenFOAM/ThirdParty-2.2.1/ParaView-3.12.0/VTK/IO/vtkOpenFOAMReader.cxx, line 6481 vtkOpenFOAMReaderPrivate (0x2e89940): Error reading line 675043 of /media/ag600/D1/FrancescoLatella/TEST_MYMULTIREG_V7/processor39/0.0011/fluid/T.gz: Unmatched } p, li { white-space: pre-wrap; } Code:
boundaryField { top { type regionCoupleHeatFlux; neighbourRegionName fluid; ownRegionName solid; neighbourPatchName bottom; ownPatchName top; neighbourFieldName T; ownFieldName T; ownThermalConductivity KS; value } Code:
boundaryField { top { type regionCoupleHeatFlux; neighbourRegionName fluid; ownRegionName solid; neighbourPatchName bottom; ownPatchName top; neighbourFieldName T; ownFieldName T; ownThermalConductivity KS; value nonuniform List<scalar> Which should be the reason? If anyone could help me I will be really thankfull! What I was thinking is that, maybe a did some error in the solver's code when I create the solid and fluid meshes. I say this because I'm not really sure about what I did because interFoam 7 use the dynamicFVmesh class instead of the normal static mesh class, so I tried to use this new class just trying to modify arguments and see what happen. I put also my createDynamicMesh.H file here if anyone will see some error in how I used this class Code:
Info<< "Creating meshes " << runTime.timeName() << nl << endl; // ********************************************************************** // Fluid mesh // ********************************************************************** autoPtr<dynamicFvMesh> fluidmeshPtr ( dynamicFvMesh::New ( IOobject ( "fluid", //dynamicFvMesh::fluid, runTime.timeName(), runTime, IOobject::MUST_READ ) ) ); dynamicFvMesh& fluidMesh = fluidmeshPtr(); // ********************************************************************** // Solid mesh // ********************************************************************** autoPtr<dynamicFvMesh> solidmeshPtr ( dynamicFvMesh::New ( IOobject ( "solid", //dynamicFvMesh::solid, runTime.timeName(), runTime, IOobject::MUST_READ ) ) ); dynamicFvMesh& solidMesh = solidmeshPtr(); |
September 11, 2020, 08:07 |
Error in the post
Francesco Latella
Rep Power: 6 |
Thank you in advance to anyone will help me!
September 11, 2020, 10:43 |
#3 | |
Mark Olesen
Rep Power: 40 |
Having "value" with nothing else looks pretty bad. You might want to review how boundary condition is actually emitting the values. Starting with OpenFOAM-v1712, many of the dictionary write key/value constructs were augmented with a simpler Ostream::writeEntry() method, but the older methods were left intact (for compatibility etc). However you are using the openfoam.org version, you probably needed to rewrite some of your output code. Some of the more recent openfoam.org versions did something similar to the openfoam.com version, but decided to make it an output template instead of a method and removed the old methods. Although it generally should work, but it could be that you are missing a template specialization somewhere that is causing your output to be swallowed. Not really sure what else to suggest. Depending on which models you use, could also try with OpenFOAM-v2006 and see how that works out. |
September 12, 2020, 09:11 |
Francesco Latella
Rep Power: 6 |
Hi Olesen, thank you for the quick reply. Here is how my boundary conditions do the output I guess
//- Write void Foam::regionCoupleTemperatureFvPatchScalarField::write ( Ostream& os ) const { fvPatchScalarField::write(os); coupleManager_.writeEntries(os); os.writeKeyword("Kappa") << Kappa_ << token::END_STATEMENT << nl; writeEntry( os, "value"); //writeEntry("value", os); } and I guess that the line that makes me problems is "writeEntry( os, "value");" but unfortunately I'm not familiar with this part of a code so it's a bit tricky for me to understand how to modify it. Consider that, this code is working in the 2.2.1 version of OF but not in the 7. |
class, conjugate heat transfer, dynamic mesh, interfoam, paraview |
Display Modes | |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
''unknown radialModelType type Gidaspow'' PROBLEM WITH THE BED TUTORIAL | AndoniBM | OpenFOAM Running, Solving & CFD | 2 | March 25, 2015 18:44 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 01:27 |
[General] Paraview Plot Temperature 3D | boristheblade | ParaView | 0 | May 25, 2012 20:37 |
