What is the difference between taking mass flow rate from Openfoam and Parafoam?
Old   November 23, 2020, 08:57
Question What is the difference between taking mass flow rate from Openfoam and Parafoam?
Merve Akkus
Makkus is on a distinguished road
Hi dear Foamers,
I am trying to understand whether my converged Openfoam solution is true or not. To estimate the accuracy of the solution I am observing the mass flow rate for inlet and outlet patches. I am modelling a square pipe geometry with simpleFoam and buoyantSimpleFoam.When I search how to find the mass flow rate in Openfoam, I found 2 ways:
1. It can be find from Openfoam postprocessing:
by typing postProcess -func 'flowRatePatch(name=inlet)' -latestTime in terminal,
2. It can be find from Paraview:
1. calculate with Mag(U) from calculator
2. apply Extract Block filter
3. apply Integrate Variables filter
(By the way, I am using air at room temperature, so its density is 1, it's density won't be change because of the incompressible flow)
These two ways are giving different mass flow rate values. I am wondering about what is the difference between finding mass flow rate from Openfoam postprocessing and Paraview?
I would be glad if you help.
Makkus is offline   Reply With Quote
flowratepatch, massflowrate, openfoam, paraview, postprocess
What is the difference between taking mass flow rate from Openfoam and Parafoam? Makkus OpenFOAM Post-Processing 4 October 27, 2021 16:27
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
OpenFOAM 5.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 11 June 5, 2018 23:48
[OpenFOAM] OpenFoam (Ubuntu): paraFoam via Xming+PuTTY raketenmaid ParaView 4 February 5, 2013 05:20
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
