December 14, 2020, 12:18 |
Calculate bulk water temperature
Rep Power: 6 |
My model is a long, horizontal cylinder filled with water and I want to calculate the heat exchange between cylinder and fluid, usinf OF8 and chtMultiRegionFoam.
To compare my results with given literature, I need to know the gradient, dTwater/dt, or in other words the change of bulk water temperature in °K per second. My problem right now is how to calculate the bulk temperature. As I understand it, it is the average temperature for a volume. I followed this explanation for paraView Average temperature in a portion of my domain, applying the filter "Integrate variables" on my of cells. In the spreadsheet, I switched attribute from Point Data to Cell Data. Then I divided the value under the T column by the Volume. Does anyone know if this is the correct approach for my problem, or if there is another one? |
Mapping bulk temperature of channel and moutend cylinder flow cases into field | focus111 | OpenFOAM Post-Processing | 0 | June 20, 2019 13:05 |
What is the accurate and best way to calculate bulk or mean temperature? | Shomaz ul Haq | FLUENT | 9 | December 23, 2018 03:48 |
calculate particle temperature gradient with user routine | amd18 | CFX | 1 | April 3, 2017 11:32 |
Bulk Temperature | Zohud | FLUENT | 3 | February 23, 2017 13:14 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
