January 17, 2021, 19:21 |
unable to visualize alpha.water in paraview
Deutschland
Rep Power: 5 |
Hey everyone,
I am trying to create my own case with the air-water interface. I ran the command setFields in the terminal and I did not get any error. I am also getting the alpha.water file with '0' and '1'. But for some reason, I am unable to view the resultant field in ParaView. I have attached the link to the screen record of me trying to view the results in the ParaView along with this. alpha.water is not appearing in the drop-down button where 'solid colour', 'vtkCompositeIndex' etc... Since that is not visible in the video I have also attached a picture which shows it. video https://drive.google.com/file/d/16Tu...ew?usp=sharing picture https://drive.google.com/file/d/1Lhc...ew?usp=sharing Can anyone tell me the reason for this? Thank you in advance Kind regards vava10 |
December 23, 2022, 09:33 |
Rep Power: 3 |
Hi! Did you find the reason for this problem?
January 2, 2023, 04:03 |
Yann
Rep Power: 26 |
Hard to answer without the screenshot, but my best guess is you have to untick the "skip zero time" in ParaView when loading your case in order to load the 0 time variables. Cheers, Yann |
December 21, 2023, 04:55 |
visualize the alpha.water
atilla altintas
Rep Power: 15 |
It is an old post, but for anyone need an answer the below might help:
In case you run a simulation on OpenFOAM for a multiphase flow and can not visualize the alpha.<liquid> field, you may try below: 1. Filters -> Alphabetical -> Extract Surface 2. Extract Surface (right click) -> Alphabetical -> Generate Surface Normals. Hope that helps someone. |
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 03:35 |
Negative min alpha.water values | nschulman723 | OpenFOAM | 2 | June 29, 2021 23:28 |
negative min.(alpha1) value interFoam | Arjun Jayakumar | OpenFOAM | 11 | December 21, 2019 10:59 |
[OpenFOAM] how to visualize a derived quantity in paraview | chandisasmal | ParaView | 2 | March 23, 2017 13:36 |
unable to run paraview | yoddha24 | OpenFOAM Installation | 4 | May 6, 2013 00:10 |
