Question for setting User Defined Variables at runtime for monitoring |
Donghun Kang
Rep Power: 3 ![]() |
Greetings,
I am a beginner of OF. I have trouble compiling user defined variable (pprime) in the system/controldict. (version: v2012) functions { pprime { type coded; libs (utilityFunctionObjects); name pprime; writeControl timeStep; writeInterval 1; codeWrite //(or codeExecute) #{ const volScalarField& p = mesh().lookupObject<volScalarField>("p"); const volVectorField& U = mesh().lookupObject<volVectorField>("U"); volScalarField pprime ( IOobject ( "pprime", mesh().time().timeName(), p.mesh(), IOobject::NO_READ, IOobject::AUTO_WRITE ), p ); pprime=p-101325; #}; fields ( pprime { base time; } ); } } I referred to Create registered object at runtime using a functionObject But mine does not work, showing: --> Could not load "... Before running, is there any command to compile? My current sequence to simulate is mpirun -np 16 rhoPimpleFoam -parallel Thanks, Paul |
Rep Power: 12 ![]() |
Without seeing the full error it is hard to help. However, if we check out the codedFunctionObject.H file, we find the following template :
{ type coded; libs (utilityFunctionObjects); // Name of on-the-fly generated functionObject name writeMagU; codeWrite #{ // Lookup U const volVectorField& U = mesh().lookupObject<volVectorField>("U"); // Write mag(U)().write(); #}; } Code:
pprime { type coded; libs (utilityFunctionObjects); // Name of on-the-fly generated functionObject name writePPrime; codeWrite #{ // Lookup p, name pprime const volScalarField& pprime = mesh().lookupObject<volScalarField>("p"); //Update pprime pprime -= dimensionedScalar("refP", pprime.dimensions(), 101325); // Write pprime.write(); #}; } Caelan |
Donghun Kang
Thanks Caelan!
I have resolved that issue ![]() Paul |
Display Modes | |
UDF value to large for defined data type | Anna73 | Fluent UDF and Scheme Programming | 9 | September 30, 2018 22:18 |
Read Result Files or User Defined Result | Aquilaris | ANSYS | 0 | February 9, 2011 05:25 |
User Defined Scalar (UDS) question (units) | D | FLUENT | 0 | March 1, 2006 20:04 |
Usage of user defined functions | Gowrish | FLUENT | 1 | October 26, 2005 07:44 |
User defined memory | Hp | FLUENT | 0 | September 24, 2004 00:10 |
