How to force function object writing only to a file?
Hi
Is it possible to set a function object (e.g. wallHeatFlux) to be written as field into time directories only at prescribed times and written to the file more frequently? For instance, if I have in controlDict Code:
application rhoPimpleFoam; Code:
functions But in the postProcessing directory the output will also be only written in these times. Is it possible to set HF to be written in time directories only at writeTime and writing to the file in postProcessing directory more frequently? |
