Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Error when sampling a symmTensor variable
Old   September 3, 2021, 07:30
Default Error when sampling a symmTensor variable
Ehsan Asgari
syavash is on a distinguished road
Dear Foamers,
I am using OpenFOAM v2012. When I input a symmTensor quantity to be sampled via the command "postProcess -func samplePlanes -latestTime", I get the following error:
Executing functionObjects
--> FOAM Warning :
--> FOAM FATAL IO ERROR: (openfoam-2012)
Entry 'type' has 1 excess tokens in stream
    2(tensor symm)
file: fields.UPrime2Mean at line 0.
The UPrime2Mean is the quantity of interest. It exists in the database but apparently foam has some issues with it. I use the following dictionary in the "samplePlanes" file:
samplePlanes
    type            surfaces;
    libs            (sampling);
    surfaceFormat   ensight;
    writeControl    writeTime;
    fields          (U nut UMean nutMean UPrime2Mean);
    surfaces
        symmPlanes
            type        cuttingPlane;
            planeType   pointAndNormal;
            pointAndNormalDict
                point   (0 0 0);  // slightly inside the domain
                normal  (0 0 1);
//            offsets ( 500 1000 1500 2000 2500 3000 3500 4000 4500 );
As seen in the code above, there are other quantities for sampling. However, only UPrime2Mean is causing problem. I was wondering if this is a bug?
I appreciate any hint.
Sincerely,
syavash
syavash is offline   Reply With Quote
sampling interval and sampling frequency beauty FLUENT 9 October 25, 2021 03:09
[waves2Foam] surfaceElevation sampling utilities katakgoreng OpenFOAM Community Contributions 2 November 18, 2016 06:27
Modeling sampling valve in CONVEARGE williamchina CONVERGE 2 September 13, 2016 02:16
Possible bug or limitation in stl-generated surface for sampling analysis Ali Blues OpenFOAM Post-Processing 3 April 27, 2016 10:30
sampling Data during calculation JimKnopf OpenFOAM Post-Processing 0 May 27, 2011 05:10
