Postprocess: sampleDict works but creates no output folder
Hi everyone,
for postProcessing, I would like to sample the pressure along a line. I have created the following sampleDict in the system folder: Code:
/*--------------------------------*- C++ -*----------------------------------*\ To run the code, I use postProcess -func sampleDict. It runs without errors, but no output folder is created. I have read similar issues, but they could be solved by adding libs ("libsampling.so");. So in my case, that is not the issue. Any ideas? I am using openFoam 5 btw. |
What is the name of the file? is it sampleDict or something else?
The name is sampleDict, yes.
Could you post the log file when you run the function object?
postProcess -func sampleDict | tee log |
Yes of course. Unfortunately, I will only be able to do that on sunday.
But there wasnt a single error. It run for every time step, without errors. Really weird. |
Hi again and sry for the delay, I couldnt make it yesterday.
Here is the log: Code:
/*---------------------------------------------------------------------------*\ Ignore the warning, they are because of a self compiled boundary condition which is not compiled on this particular computer. On the other one its the same, just without the warning. |
What about this warning? Code:
--> FOAM Warning : Looks like there is a typo in your controlDict. Yann |
Hi Yann,
you are absolutely right, my bad. Here is the right one: Code:
Doesn't it solve your problem?
This part of your log file is different in the last log file compared to the previous one: Code:
Reading fields: |
That's what is weird about it. It does something, but I get no postProcessing folder with the data.
Can you try running it this way?
yourSolver -postProcess -func sampleDict (or the parallel equivalent, if you are running your case in parallel) |
I also tried this one and it did not work either.
But by lucky conincidence, I just found the problem. Including: Code:
FoamFile at the beginning solves the problem and an output file with the data is created. |
I didn't notice you didn't have a full header in your sampleDict but I would never have suspected if would behave this way. I would rather have thought you would just get an error.
Glad you could solve your problem, this is good to know! Yann |
Yeah same here.
Next time I will just copy and paste it from a tutorial like I usually do, then this mistake wouldnt even had happened haha. |
