Vector Field by Time Step
im new in the field of the software OpenFoam. I had made some simple Simulations of diffrent bodys (a cylinder as a example) with this porgram. For Post Processing i started to use Paraview. My question is: For my project i need a way to export the vector-data from the flow for each timestep. For the start i simulated a clyinder in the center of the box, one side is the inlet,the other side the outlet. The walls are my Boundaries. I try to hold it simple to better implement my thoughts. Now.. can someone help me and can explain how i can fix the problem. Is the data that are exported from OpenFoam in this format, or can i load it in Paraview and export it from there in the wished format? :confused::confused::confused: I hope you can understand my problem/thoguths. For help i would be very thankful.:cool: Take Care. Vortex123 |
