August 1, 2023, 22:18 |
no y+ data in cell center but in point
LeeMyungYeon
simulate NACA0012 case with SA turbulence model in OpenFOAM11
after computation, i do postprocess for calculating y+ with using "foamPostProcess -solver incompressibleFluid -func yplus" command and check the results with paraFoam but in the paraFoam there is no y+ data in cell type but in point type i thought all calculation is done in cell center and OpenFOAM create point data with interpolation. so y+ should be created in cell center and point any opinion or reference, why y+ is created in only point data |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
UDF in case with DPM modle | POSTHU | Fluent UDF and Scheme Programming | 0 | March 3, 2021 07:21 |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
How to get cell data like center, volume/mass, velocity | julianschl | OpenFOAM Post-Processing | 3 | June 13, 2014 03:10 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
