How to calculate fluctuating velocity and turbulence intensity in RANS (OF) |
January 26, 2019, 19:25 |
Hello, senior Fomers.
I am new to CFD field and currently, I am doing a simulation of T3A tutorial case which uses kOmegaSSTLM model. I have to calculate turbulent intensity and plot it on a graph along a line very close to the flat plate surface. I used the postProcessing tool named "turbulenceIntensity" and plotted a graph along a line which I drew along the flat-plate-wall. The problem is I am getting a very weird graph. The image should be here: Can you please tell me where I am making mistake? (((BTW, I want to also know what are the three columns in U file represent?))) Thank you very much. Last edited by purnp2; January 27, 2019 at 19:40. Reason: Better way of asking: |
February 8, 2019, 05:42 |
Zander Meiring
Rep Power: 7 |
the three columns in the U file represents the x, y and z components of velocity. I'm not sure what you mean by the fluctuating velocity, but if you're talking about turbulent velocity fluctuations (u') then you won't be able to model that with RANS equations, as their whole purpose is to remove the fluctuating component and average it out
September 20, 2020, 21:49 |
Ashutosh
Hello friend i saw discussion it's true with rans model we cannot calculate u'instantenous sir if am using LES model and i have umean and uprime2mean how can i find value of u' instantaneous velocity
September 22, 2020, 08:06 |
Pedro Pacheco
Rep Power: 6 |
Hello Ashutosh,
According to Reynolds decomposition: U = Umean + U' So all you have to do is subtract from the U(x,y,z,) field the Umean(x,y,z). In paraView, for example, you can do this by setting a Calculator filter. Hope this helps. |
April 11, 2022, 12:47 |
Pedro Pacheco
Rep Power: 6 |
As a matter of fact my previous post does not apply to RANS results... Only for LES results, where U - Umean is the resolved part of the velocity fluctuations.
I apologize if I misled anyone! |
flat plate, fluctuating velocity, turbulent intensity |
Display Modes | |
Average Turbulence Intensity in LES | M_Hego | Visualization & Post-Processing | 0 | July 24, 2018 15:18 |
possible to have a controller on inlet turbulence intensity? | mrshives | CFX | 6 | February 2, 2016 17:55 |
Turbulence Intensity & Velocity | mohammad_mec87 | Main CFD Forum | 16 | December 23, 2014 16:36 |
Question on Turbulence Intensity | Eric | FLUENT | 1 | March 7, 2012 04:30 |
About Turbulence Intensity (Pipe flow assimilated) | gRomK13 | Main CFD Forum | 1 | July 10, 2009 03:11 |
